Brake Fluid Flush
Old May 24, 2006 | 11:30 PM
jah13's Avatar
jah13
Default Brake Fluid Flush
I own a 1998 C5 with 18K original miles. Should I change the Brake fluid given the age of the vehicle?
Old May 24, 2006 | 11:39 PM
wamara's Avatar
wamara
Cruise-In II Veteran
It would be the preferable thing to do. I am under the impression that water in the fluid could have a deleterious effect on some of the brake components. The factory brake fluid absorbs moisture from the air; it will occur as a function of age, not mileage.
Old May 25, 2006 | 12:33 AM
99FewteRC5's Avatar
99FewteRC5
it wouldnt hurt
Old May 25, 2006 | 04:06 AM
CARRJET's Avatar
CARRJET
If the fluid is dark it probably has absorbed moisture along with other contaminates from normal wear. I have a 99 and have changed the fluid when it darkens, not to difficult if you just use a turkey baster and suck it out refill , drive then repeat untill it is golden....good luck
Old May 25, 2006 | 08:16 AM
jovette's Avatar
jovette
Yep, just did this on my '00 Coupe with 13,700 miles. The brake fluid was dark, so I just purchased a few of the small cans of DOT 3 fluid and sucked out the old and poured in a new can. Then drive 500 miles and do it again until the fluid stays pretty darn clear, as it is when new. It's interesting that following this method, uses just about the entire can, which is good, since once opened, you really shouldn't use the brake fluid out of un unsealed can, due to the hydroscopic nature of the brake fluid. (meaning it attracks and retains moisture/water as has been noted) I've been doing this sort of brake fluid 'change for years now in all of my autos, seems to work great for me.
Old May 25, 2006 | 09:49 AM
yellow01's Avatar
yellow01
This method is ok if you are street-driven only as you will never see high enough brake temps to make water absorption a major issue. It's still a good idea to replace fluid to avoid corrosion though.
The best and complete way to do this is to remove all old fluid from the resevoir as people have said, then bleed all four calipers. The fluid in the calipers is what is exposed to the majority of heat and it is important to have fresh fluid in the calipers. Replacing only the fluid in the resevoir will not necessarily refresh the fluid in the calipers - there's alot of hardline between the resevoir and calipers.
Also, the moisture in the old fluid left in the lines will more quickly contaminate the new fluid.
A complete flush/bleed is really pretty straightforward if you have the ability to get the car up and have basic tools. You can even lift one corner at a time and do it, it is just more of a PITA that way. You'll need speed bleeders, a motive, OR a buddy/wife willing to press the brake pedal a few hundred times
I had to buy a motive, my wife gave out after the first full bleed
To Brake Fluid Flush
