Door will not unlock..
Old May 25, 2006 | 11:44 AM
EB-Z06's Avatar
EB-Z06
Default Door will not unlock..
I'm having a problem with the driver's side door not wanting to unlock.
The door will lock every time but will occasionally UN-lock. Seems like when its cold it'll unlock, but once it get warm outside, it'll act up. (Yeah, I know sounds stupid.)
What would be the problem? Door lock actuator (sp?) or could it be something else since it only does every now and then?
Thanks in advance!
Old May 25, 2006 | 11:50 AM
nikolai's Avatar
nikolai
I had this problem last year on my driver's side. Almost, but not every, time I would park it and want to get out, for a period of about a few weeks, I would have to stick my arm out the window and open it from the outside latch
It was a tiny piece of the door lock actuator being broken. I ended up having it replaced no charge under my warranty and everything was fine after that.
I would start with looking into that.
Nick
Old May 25, 2006 | 12:09 PM
EB-Z06's Avatar
EB-Z06
It seems to be a power issue or something.. It's not making a noise at all when I try to unlock.
It works when I lock though..
Thanks for the suggestion! I'll see if I can try to look more into that!
Old May 25, 2006 | 02:08 PM
feeder82's Avatar
feeder82
see this thread : http://forums.corvetteforum.com/show...327&forum_id=1
Old May 25, 2006 | 02:10 PM
nikolai's Avatar
nikolai
If I recall correctly, mine wasn't making any noise either when I would try to unlock it...
Old May 26, 2006 | 09:00 PM
LS6 TECH's Avatar
LS6 TECH
I'd bet you have a bad driver door control module. To check you need to remove the door panel. Disonnect the door lock actuator. Install a headlamp buld across the two terminals. Operate the switch in both directions to see if the bulb lights. If it only lights in one direction you have a bad module. You must use A halegen headlamp light bulb and not a test light. A test light does not draw enough AMPs.
Old May 27, 2006 | 11:33 AM
EB-Z06's Avatar
EB-Z06
That's good info!! Thanks!
Old May 27, 2006 | 12:24 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
When driving what does you voltage meter read? I have found if the voltage is to low your fob will not work the pass side door locks.
Ron
To Door will not unlock..
