SpeedBleeder Install Question
Old May 25, 2006 | 12:26 PM
indy300's Avatar
indy300
Default SpeedBleeder Install Question
How do you install speedbleeders (or normal bleeders)? Won't brake fluid gush out everywhere. Will this affect or remove the new threadlocker.
thanks.
Old May 25, 2006 | 01:09 PM
Uncle John's Avatar
Uncle John
Well...no. The bleeders are on top of the calipers so nothing will "gush out" unless you decide to pump the brake pedal while you're in the middle of changing them. Just unscrew the old ones (I think they're 10mm) and reinstall the new ones. Since you "cracked open" the brake system, you'll get to try them out right away.
Old May 25, 2006 | 01:42 PM
dbirdz06's Avatar
dbirdz06
I had a small amount of fluid come out while installing mine, but not much. Should be an easy swap for you. If you work on your brakes more than once a year, you will enjoy these.
Old May 25, 2006 | 03:46 PM
yellow01's Avatar
yellow01
You'll have some fluid loss - similar to a gravity bleed, but not too much. It will be enough to make some spots on your garage floor, so I recommend having a towel underneath and handy to wipe down the caliper around the bleed screw when you replace.
Did you say 'threadlocker'? As in loctite? No need to use any of that, the speedbleeders come with a sealant on the threads already.
Old May 25, 2006 | 05:02 PM
Dirty Howie's Avatar
Dirty Howie
Its simple and very little mess. Make sure you get the new ones completley seated ( I had one start leaking at the track). And as stated above use them right away to bleed as you put them on. I would put them on in the same order as if you were doing a brake job...for my car its RR, LF, LR then RF
They are great (I got the SS ones)
DH
Old May 25, 2006 | 06:49 PM
LoneStarFRC's Avatar
LoneStarFRC
DH
Old Jul 17, 2006 | 06:02 PM
indy300's Avatar
indy300
What is the benefit of getting the stainless steel speedbleeders as opposed to the regular speedbleeders?
Which one do I get: SB1010; SB1010s;
thanks.
Old Jul 17, 2006 | 08:15 PM
csexton's Avatar
csexton
Great mod!
Chuck
Old Jul 17, 2006 | 08:19 PM
Dirty Howie
thanks.
I got the SS for piece of mind ....... still was a cheap mod
DH
Old Jul 17, 2006 | 08:25 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Originally Posted by csexton
Great mod!
Chuck
Old Aug 1, 2006 | 05:03 AM
Vette_Fan's Avatar
Vette_Fan
On Ebay $6.00 + $1.50 shipping for a SET of 2.
Lingenfelter $15.95 + shipping (?) for a SET of 2.
Raceshopper.com $12.95 + shipping (?) for a SET of 2.
The raceshopper.com & Ebay had shown the exact same picture of the item. Though all 3 websites show exactly the same item, with similar details.....
So, does anyone have a preference of where to buy from, or where you bought from. Personally, I like to save every buck, and still get a good product...
Old Aug 1, 2006 | 07:03 AM
briann510's Avatar
briann510
I tried speed bleeders on my Trans Am and 2 of them wouldnt seal, and I never used them again. I dont trust them period sealing completely.
Old Aug 2, 2006 | 02:12 PM
Dirty Howie
Mine work great.....
DH
Old Aug 2, 2006 | 05:43 PM
Vette_Fan's Avatar
Vette_Fan
This question is for people who are "Satisfied" with their speedbleeders. Can you plz tell us, where go bought them from, seems like there are a few different kinds out there. That's why some ppl are happy with them, and some are not...
Thanks..
Old Aug 2, 2006 | 07:01 PM
ge2001's Avatar
ge2001
I bought mine 2 weeks ago from speedbleeders.com and the install was simple. No leaks, work great.
Old Aug 2, 2006 | 07:11 PM
Vette_Fan's Avatar
Vette_Fan
That seems to be a software website..
Old Aug 2, 2006 | 07:22 PM
c4cruiser's Avatar
c4cruiser
The Raceshopper price seems like a good considering their ad says you get the bleeder bag with 2 pair of SpeedBleeders. I have one of the bags and it makes bleeding the brakes very simple and there is no spilling of fluid. Hook one end of the supplied hose on the bleeder, open it a 1/4 turn and push the pedal.
I bend the end of the included 3' tube at the end and clamp it. When I get home, I simply dump the contents of the bag into an old bottle. The bag and a small wrench goes into a gallon-sized Zip-Lock bag to seal everything up.
To SpeedBleeder Install Question
Old Aug 2, 2006 | 09:02 PM
indy300's Avatar
indy300
google speed bleeder and see what comes up
Old Aug 3, 2006 | 04:43 PM
JObranovich's Avatar
JObranovich
DH
Where did you buy them from? Are they Stainless Steel or are you referring to the 's' at the end of the part number as stainless steel? I thought the 's' meant short because there is a difference between the ones for a C4 and C5.
Old Aug 4, 2006 | 04:14 PM
Dirty Howie
I'm pretty sure I bought them from Speed Bleeder website.
And also pretty sure the "S" was for Stainless.
DH
