Oil Temp Question
john
A sunthetic should be good to about 290....
But I use Roy,al Purple Purple Ice in my Dexcool and run a VaraRam.
The combination of cold air intake and surfactant in the rad leaves me at maximum 195 coolant and 220 oil.
Bill
My personal comfort range for high rpm driving with a 30 weight is below 240F.
As for normal temps in stop and go traffic in hot weather, the oil temp will follow the coolant temp. On the high end, the coolant temp is controlled by the fans. Though the fan setpoints appear to have varied slightly over the years, they are about: low speed on at 226, off at 219; hi speed on at 235, off at 226. So in stop a go traffic, it is not abormal to see temps of 230 or so. Thus an oil temp in the 230s to 240s isn't abnormal either.
Other things to consider are that when the AC condensor is on, the fans will run, thus if it is hot enough out for the AC to run and the fans are on, but the load on the engine is low or airflow through the radiator is high, the temp will go down to the 194 range where the thermostat will go closed.
The car can reach an equilibrium in between 194 (thermostat closes) and 219 (fans come on) dependent on engine load and airflow/airtemp flowing through radiator, thus you see many guys say their car runs near 200-210.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Don't the fans go off even if the AC is on when you get over a certain MPH ( I think 40mph)???
DH
Thanks Howie. I believe you are correct about a speed input, but I can't find a discussion about it in the service manual section on cooling. Maybe someone with LS1 Edit can confirm there is a setpoint for that.
