tire air pressure problem
Old May 27, 2006 | 11:45 PM
burnin red's Avatar
burnin red
Default tire air pressure problem
I have a 1998 c5 that I just put HRE wheels on, and I have a set of pressure sensors, but where they attach to the valve stem does not work because of the different shape inside the wheels, what do I do so I can use my air pressure sensors?
Old May 28, 2006 | 04:01 AM
99FewteRC5's Avatar
99FewteRC5
either glue them on the inside of the wheel or get some big clamp(looks like hose clamps) from hardware store and band then to the inside of the wheel.
Old May 28, 2006 | 07:06 AM
SpeedyD's Avatar
SpeedyD
If you call HRE they also sell air pressure sensors that work with the wheels. Good luck with the wheels!! Thanks, Dan
Old May 28, 2006 | 10:14 AM
burnin red's Avatar
burnin red
awesome, thank guys I am on it
Old May 28, 2006 | 11:20 PM
Awsum98's Avatar
Awsum98
you can also grind off some of the rubber and shape them to fit !!
Old May 28, 2006 | 11:27 PM
ZZ's Avatar
ZZ
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
This is how HRE sent them to me when I bought mine 7 years ago. The sensors worked fine.
To tire air pressure problem
