In the last few weeks I have been getting a clunk/pop in the right front wheel area and I can't find it.
When it started it only happended when I turned or just before a stop under 5MPH. On the way home from CI VII it starting to do it when I go over bumps and up to around 40MPH. It happens more when I'm slow and turning.
I have read severad threads and nothing has helped.
I have taken the front sway bar off to make sure the end links and sway bar are not the problem. The clunk/pop seems to be less but I think the sway bar is helping transmit the noise through the frame.
I have pulled the tie rod end off the spindel and it seems to be fine. I can move the spindel back and forth with no binding or popping.
I have checked the caliper, shock, and mono spring to make sure they are tight.
we learned that at the CI , did you ck the torque on the upper and lower control arm bolts? i've seen a few cars w/ the bolts loose, while your in there i'd ck the brake bracket/caliper bolts also
The tie rod end is not as smoth as I think it should be. If I turn it with an allen wrench it makes some noise without a load on it. It may be transmitting the noise through the spindel and into the frame.
I'll order a new one in the AM. None of the part stores have one.
