what do these codes mean?
Old May 30, 2006 | 03:24 PM
brandon1566's Avatar
brandon1566
Default what do these codes mean?
P1571 ASR Desired Torque
C2120 TPM System Malfunction (No Sensors Received)
Old May 31, 2006 | 01:42 AM
brandon1566
no one?
Old May 31, 2006 | 11:09 AM
Stealthy4's Avatar
Stealthy4
St. Jude Donor '06
I believe this one is part of the torque management system. This is a pretty common code to pull especially in early C5s. Mine pulls this all the time but ive never seen it as a C (current) code. It is always an H (history) code for me. The system probably receives a voltage that is slightly high or low and then it sets the code. I don’t know the exact root cause but it shouldn’t hurt anything. Heres a website to check out.
http://www.gearchatter.com/viewpost1...56f05c74e70cc2
This code refers to your TPM (tire pressure monitor) system. Coupe and converts come with a TPM sensor in each wheel that is energized via a small battery in each sensor. When the battery goes dead, the signal from each wheel to the car is lost, hence no sensors received. If you have aftermarket wheels, the sensors may not have been compatible, and hence were removed. Or if they were compatible, they somehow became unprogrammed with the car. You can do a TPM system relearn procedure but if the sensors are missing or all four have dead batteries, it is useless. The batteries are replaceable but it takes a lot of work because they were NOT designed to be replaceable. A new set is between 250-400 bucks for all four…
To what do these codes mean?
