11 sec c5's come inside
Old May 30, 2006 | 05:55 PM
N0TDADYS_98's Avatar
N0TDADYS_98
Default 11 sec c5's come inside
how did you do it?
Old May 30, 2006 | 06:06 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Originally Posted by N0TDADYS_98
how did you do it?
Stepped on the gas pedal really hard.
Mine is a 2001 A4 coupe. Vararam, LG Pro long Tube Headers, UD pulley, G5X3 cam, 3.73 gear, SS3600 T/C, and a good LS Edit tune. 11.62 at 119+mph, so far. Putting on heads, intake, and a ported throttle body in a few months. Hoping to get the stars aligned just right and pull off a 10 second pass. Good Luck with your mods.
Bob
Old May 30, 2006 | 06:09 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I am pretty sure that my setup (see sig) will put me in the 11s, but I have bot been able to get to a track and I think my tires will be an issue.
Old May 30, 2006 | 06:22 PM
N0TDADYS_98
what would be the min. size cam i could use to get into the mid 11's with LS6 heads, LS6 intake, CAI, TSP headers (connecting pipes) & corsa?
Old May 30, 2006 | 06:24 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I would run a cam that has a 112 LSA, 228/232 (something around there) and in the .58X. I think that you should see high 11s with that.
Old May 30, 2006 | 06:34 PM
16Again's Avatar
16Again
Are the heads ported? how much? What gears are you running? A4 or 6 speed? My suggestion would be, speak to your local tuner and let them know exactly what you are looking for from your car. They should be able to aim you in the right direction.
Old May 30, 2006 | 06:42 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
how did you do it?
On my M6: Z06 clutch, Kumho MX's, hardened output shaft, a 150 wet shot and Vortex Rammer netted me 11.997 @ 123. I couldn't spray until halfway through first or I would go up in smoke. Tires are an important part of any complete breakfast...er sub 12 second quarter mile.
I haven't been to the track with the blower but I know I'm ~50-75 HP stronger now. I need a new clutch and DR's to really tell how deep into the 11's I am.
Old May 30, 2006 | 07:37 PM
N2O4YOU's Avatar
N2O4YOU
I did it with a K&N Filter and 100 shot on Nittos. Clutch won't hold long or at least mine only made about 10 runs on the spray. Headers, intake, 100 shot, Clutch, 3.90's got me mid 11's all day long with poor traction from the nittos.
Old May 30, 2006 | 07:49 PM
IFLUBYU's Avatar
IFLUBYU
See sig.
Old May 30, 2006 | 07:53 PM
sams96's Avatar
sams96
Full exhaust,tune,stall,gears,et streets. Stock LS1 intake,tb,wp,heads,cam 11.64@118
Old May 30, 2006 | 08:14 PM
berryj's Avatar
berryj
Did it w/ Andy's P1 procharger kit and 3.42 rear on my A4 (see sig below). Ran 11.3 on a 65 degree day and 11.8 in hot weather.
Old May 30, 2006 | 08:27 PM
jhong321's Avatar
jhong321
To make it into the 11's it will depend on a few things.
If you are a auto then it will make it a little easier. Just get a big stall (torque converter) a cam and bolt ons and some dr's If you can put ont about 360 rwhp then you could be in the 11's
Now if you are a manual trans then it will get harder. You will need more ponies to get it done and more track time to increase your shifting time. You will need to get 400 + rwhp
I have seen many people that have more then enough HP but still could not break into the 11's there first time out or even 2nd or 3rd. (including me I finally made it with some good dr's)
Good luck
Old May 30, 2006 | 08:53 PM
16Again's Avatar
16Again
Good luck
Actually you have that reversed. If it's an automatic you will need more horsepower. 6 speed cars are quicker/faster than auto's. This is due to the drive train loss caused by the automatic transmission.
Old May 30, 2006 | 09:30 PM
jhong321's Avatar
jhong321
I know that it will loss more to the drive train but at the same time if you get a big stall you will make up for the less power with torque. At the same time it has been said that you will lose at least 2/10 per shift with a manual trans and after 3 shifts thats over a 1/2 secound. If you look around at alot of the big boys run you will see that they are all running auto trans. Now if you compare a stock to stock (with a stock torque converter) then yes the manual would be faster providing he knows how to really drive it.
Old May 30, 2006 | 09:37 PM
16Again's Avatar
16Again
I run an A4 for two reasons. First, I SUCK racing with a 6 speed. Second, the A4 is consistant. You will find that those of us drag racing run the auto trans for consistancy not speed. I guess it all equals out in the end.
Old May 30, 2006 | 09:49 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
all in sig, with no cam or heads
Old May 30, 2006 | 10:02 PM
jhong321's Avatar
jhong321
I would never want to bracket race against a auto car My friend run a auto and is alway in the top of the pack for the brackets and of coures i am alway 1st one out unless the other guy red lights
To 11 sec c5's come inside
Old May 30, 2006 | 10:07 PM
black98c5's Avatar
black98c5
I have seen people with just stall/gears and DRs hit 11s all day. add a cam and all the boltons to the mix and the possibilities are endless.
Old May 31, 2006 | 01:10 PM
Face's Avatar
Face
Stock heads and cam also. No spray, supercharger, turbo, etc.. It's all in the stall, tune, and tires.
Old May 31, 2006 | 01:20 PM
brandon1566's Avatar
brandon1566
11:86 @118 all stock besides dry 100 shot and bfgs in a 97 a4 with a bunch of junk thrown in the back
