led install question
Old May 31, 2006 | 01:01 PM
tagrl99's Avatar
tagrl99
Default led install question
I just installed leds in the rear view mirror lamps and in the rear cargo courtesy lights. The ones that are supposed to come on when you open the door. After installing these leds with resistors, they worked for a while and now they dont come on. The ones in the mirror come on with the switches on the bottom of the mirror, but not when you open the door. I checked all the fuses and they are all good. The only thing I could think of is the mini fuse relay (#42) for courtesy lamps under the passanger kick panel.
Has anyone done this installl, any help??
