Front Spoilers
Old May 31, 2006 | 05:43 PM
Tiger 650's Avatar
Tiger 650
Default Front Spoilers
My front left and right side spoilers are sagging down and look crappy. They are not damaged, just apparantly fatigued.
Is there any way to prop them up without drilling any new holes, or should I just replace them?
thanks!!!
Bob
Old May 31, 2006 | 06:11 PM
Mr. C's 5's Avatar
Mr. C's 5
Tiger650,
There are supports you can buy for about $20 that will re-enforce the mounting holes. I have them on both C5's and the work well. Look at Madvet, or Ecklers (or e-bay). Unless the spoler holes have been stretched, I wouldn't buy new ones. But if you have to Fitchner sells them pretty cheap. - C.
http://www.madvet.com/shop?frame=1.165.588
Old May 31, 2006 | 09:08 PM
Tiger 650's Avatar
Tiger 650
C,
Thanks! I checked the mounting holes and they are not stretched, so I will order the reinforcements. I appreciate the help.
Old May 31, 2006 | 09:16 PM
bcseitz's Avatar
bcseitz
Fichtner's has a great price for the left and right front spoilers. For the money, might as well replace them too. Here is the link.
Bob
http://temp.corvetteforum.net/c5/ken...rtspage6.shtml
Old Jun 1, 2006 | 11:46 AM
corvettebob1's Avatar
corvettebob1
Had a spare piece of sheet metal laying around so I traced out a pattern and cut it out with some tin snips drilled 4 holes and bolted them in.
Cost $0.00
Time 45 min.
If you don't have the sheet metal add $5.00 to the project.
Old Jun 1, 2006 | 12:30 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Get the replacements and take tin snips to the old one to make reinforcements by doubling up the thickness of the mounting surface.
Old Jun 1, 2006 | 01:43 PM
crvtble's Avatar
crvtble
Good Idea
Old Jun 1, 2006 | 03:40 PM
Tiger 650's Avatar
Tiger 650
Ahh...necessity is the mother of invention! I will order the replacements from Fichtner and nip the old ones to reinforce the new!
To Front Spoilers
