04' Z06 trans fluid capacity
Old Jun 1, 2006 | 09:41 AM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Default 04' Z06 trans fluid capacity
The T-56 in my 02' Camaro SS took 4 qts. of fluid. Being as though the C5 uses the same manuel case I would think it holds the same. I just want to make sure before I change to Royal Purple synchromax.
Also I am changing my diff fluid to Royal Purple Max Gear 75W90. I believe I still need to add a friction additive correct?
Thanks in advance,
Matthew
Old Jun 1, 2006 | 10:00 AM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Thanks in advance,
Matthew
The manual sez the T-56 takes 3.8L, but that's apparently a fresh fill number -- my '04 (non-Z06, but I believe the same tranny case) took about 3.4L when I changed it; that's consistent with others' reports here, between 3-3.5L.
Old Jun 1, 2006 | 10:36 AM
SilentFright
Thank you very much . Any word on the addition of a friction modifier/ additive with Royal Purple Max Gear differential fluid?
To 04' Z06 trans fluid capacity
