Wheel fitment
Old Jun 1, 2006 | 01:06 PM
402Sam's Avatar
402Sam
Default Wheel fitment
Will a wheel with a 45 offset work on our cars. I want these wheels so bad and think they will look gangster on the yellow zo6.
http://www.wheelmax.com/product.asp?ProdId=10968
3inch lip in the rear and goin to see if I can get a custom lip for the front since I want a small lip in the front, 1 inch or less.
Old Jun 1, 2006 | 01:10 PM
402Sam's Avatar
402Sam
I forgot i had to do the search for a camaro since corvette wasnt an option but if they fit a 01 fbody they should fit a c5 bolt pattern wise that is.
Old Jun 1, 2006 | 07:13 PM
402Sam's Avatar
402Sam
Anyone????
Old Jun 1, 2006 | 07:44 PM
cenzo's Avatar
cenzo
Ok, let's compare with stock Z06 wheels.
The fronts are the same width but the 45mm offset is 11mm less. So the fronts will be 11mm or almost 1/2 inch further outboard than stock.
The rears are an inch narrower and 13mm less offset than stock. This is a wash. 1/2 the lesser width (12mm) and the 13mm less offset cancel each other and the rears will extend about the same amount as stock.
The bolt pattern is the same I believe. Hope this helps.
To Wheel fitment
