Traction control active handling problems
Old Jun 3, 2006 | 12:49 AM
402Sam's Avatar
402Sam
Default Traction control active handling problems
Here we go again, ever since I installed the new motor I am now getting service traction control and active handling. Is there any grounds for this or any grounds that I need to look at for loose connections. I remember someone saying something about it possible being the battery or something that would cause this. Also is there any way to turn off active handling completely with hp tuners. The car is goin into reduced engine power mode and I cant clear the code on the DIC. Here is what I put in the car. 402 ls2 short block, ls6 heads, fast intake and 90mm throttle body. Will the throttle body have anything to do with it since it is drive by wire, maybe something there is messing with it. It seems that when the car detects any speed it throws these codes. I drove the car 100 yds if that from my garage and then here comes the codes...This thing is killing me, about to give up on it and sell it all.
Old Jun 3, 2006 | 01:01 AM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
You didn't happen to change wheels or tires while it was in the shop did you?
Old Jun 3, 2006 | 09:36 AM
402Sam's Avatar
402Sam
Nope. We took the fronts off when we pulled the short block but thats it.
Old Jun 3, 2006 | 01:00 PM
402Sam's Avatar
402Sam
Nobody can help????
To Traction control active handling problems
