Help Identify Engine Noise?
Old Jun 3, 2006 | 08:50 PM
NCDW's Avatar
NCDW
Default Help Identify Engine Noise?
My 98 (41K, AT) makes a "whining" noise under the hood after starting that goes away after about 30 seconds. It does this with car in park or in gear. It isn't loud, but is noticeable. It also sometimes comes back for a few seconds when stopped. It sounds like a motor or solenoid. Someone who heard it said they thought it was a pump associated with the anti-lock braking system and nothing to worry about. He said most cars have this pump that runs after starting and cycles on and off from time to time but you usually don't hear it. There are no codes or indicators showing any problems.
Should I be worried? Anybody had experience with this?
Old Jun 3, 2006 | 09:22 PM
cosmictrucker's Avatar
cosmictrucker
Is there any way you can record the sound via a digital recorder or video camera and post the audio for people to listen to?
Old Jun 3, 2006 | 09:30 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
It might be the air pump,Its on the driver's side,kind of behind the front blinker,if you can get underneath the car you will see a small black panel in front of the front drivers side tire,In that area.Maybe when its making that noise you can listen in that area.
Old Jun 3, 2006 | 10:51 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Old Jun 3, 2006 | 10:58 PM
NCDW's Avatar
NCDW
Thanks for the info everybody. I'll see if I can record it. I does sound like it's coming from the area of the driver's front tire/light area. I guess my real concern is that if it's loud enough to hear it, is something wrong with it?
Thanks again for the input. Love the forum!!
Old Jun 4, 2006 | 07:44 AM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Its probably just got some dust & dirt in it & the bearings are dry,If you can take it out and blow it out with an air compressor,Then put some oil or light grease in the bearings you should be good to go....................Paul
Old Jun 4, 2006 | 11:03 AM
molson's Avatar
molson
I'ts just the AIR pump...mine does the same thing.
To Help Identify Engine Noise?
