squeaking vert top
Old Jun 4, 2006 | 05:28 PM
wettvette's Avatar
wettvette
Default squeaking vert top
sometimes my vert top squeaks, i think its from the rubber strip on the deck rubbing on the seal at the bottom of the vert top. (hope that makes sense)Will silicone fix this or are there otherways.
Thanks , Glenn
Old Jun 4, 2006 | 06:18 PM
Dustydog's Avatar
Dustydog
Cruise-In VI Veteran
Cruise-In VII Veteran
It should do the trix and will help prolong the life of the seal.
My rear upper shock mount came loose and was making a squeak that I thought was vert top.
Hope this helps!
Old Jun 4, 2006 | 06:57 PM
wettvette's Avatar
wettvette
so silicone wont harm the rubber?
Old Jun 4, 2006 | 08:01 PM
GrayC5's Avatar
GrayC5
You might like to check out the following Service bulletins:
1998 Convertible: Service Bulletin: Tonneau Cover Makes Noise When Going Over Bumps
1998-2001: Service Bulletin: Squeak From Rear of Convertible Top (Replace Protector Assembly)
Too, you may want to update your profile with your car's model year and type. This could be of benefit to others when answering questions and offering assistance.
Hope this helps and good luck with the fix.
Old Jun 4, 2006 | 10:43 PM
wettvette's Avatar
wettvette
its a 2002 and it could be the hood cover,but it only does it now and again ,very random
Old Jun 4, 2006 | 11:36 PM
Sammy_C5's Avatar
Sammy_C5
yeah i can relate
To squeaking vert top
