10-PCM P1635(5v Reference #1 Circuit) CODE
Old Jun 6, 2006 | 01:55 PM
nightmel's Avatar
nightmel
Default 10-PCM P1635(5v Reference #1 Circuit) CODE
Anyone know what this references. Where should I start looking for the problem that causes this code? Any help would be greatly appreciated.
Old Jun 6, 2006 | 02:47 PM
nightmel's Avatar
nightmel
ttt
Old Jun 6, 2006 | 07:47 PM
RoadRebel's Avatar
RoadRebel
DTC P1635
Circuit Description
The powertrain control module (PCM) uses the 5-volt reference A circuit as a sensor feed to the following sensors:
The manifold absolute pressure (MAP) sensor
The engine oil pressure sensor
The PCM monitors the voltage on the 5-volt reference A circuit. If the voltage is out of tolerance, the PCM will set DTC P1635.
Conditions for Running the DTC
The engine is running.
Conditions for Setting the DTC
The PCM detects a voltage out of tolerance condition on the 5-volt reference A circuit.
The above condition is present for longer than 10 seconds.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Test Description
To 10-PCM P1635(5v Reference #1 Circuit) CODE
