Weird Headlight issue havent seen before
Old Jun 7, 2006 | 07:11 AM
Rogue Leader's Avatar
Rogue Leader
St. Jude Donor '08
Default Weird Headlight issue havent seen before
So it started with the normal drivers side headlight wouldn't pop up, no big deal, flick the switch twice it would usually go. All of a sudden it works fine now, EXCEPT if i flick from off to just parking/fogs the headlights pop up (and yes i know they stay up if you go from full up to parking), and when I drop them the drivers side makes this grinding noise after it closes for a good 10 seconds it gets progressively slower and stops. Any ideas?????
Old Jun 7, 2006 | 09:17 AM
DeeGee's Avatar
DeeGee
You've got a stripped headlight motor gear
Look in the sticky for Leaftye's write up and run down to Headlight Problems. It describes the fix.
Old Jun 7, 2006 | 06:16 PM
Rogue Leader
St. Jude Donor '08
Figured on that one, but what about the strange switch probllem??
Old Jun 7, 2006 | 11:49 PM
VetterGetIt's Avatar
VetterGetIt
I have the same problem. You need the brass gear. When you fix the gear I was told it would go back to normal.
Old Jun 8, 2006 | 12:40 AM
Rogue Leader
St. Jude Donor '08
Luckily I have brass gears from my 99TA I never used....
mint!
Old Jun 8, 2006 | 02:05 AM
VetterGetIt
Awesome!!! That worked out great for ya.
To Weird Headlight issue havent seen before
