Good Tune?????
Old Jun 7, 2006 | 04:28 PM
freemanjc's Avatar
freemanjc
Default Good Tune?????
Can anybody tell me how important it is to get a good tune(LS1 Edit) after you had a H/C swap and inserted 3:42 diff from 2:73's. Also, is a TC necessary for a mild cam 228-222 on a 114.5 lsa. Just curious?
Old Jun 7, 2006 | 04:45 PM
94legaleagle's Avatar
94legaleagle
your car will drive after these mods, but you will want to either have a "bench tune" done to your computer or a dyno tune. You will need to have the shift points adjusted due to the different rear gears, and I'd have your gas and air mix checked while you are at it just to be safe - you don't want to melt something down due to a lean fuel mix
