Need Help W/air Condition
Old Jun 8, 2006 | 01:40 PM
stingrayarde's Avatar
stingrayarde
Default Need Help W/air Condition
hey guys i have a 98 vert. i just replaced my automatic dual climate control cuz my display was gone and the AC button when pressed lights up 3 times then goes off. i tried many attemtps to use my AC but had no luck. So i purchased a new Climate Control Unit. After i hooked it up the lights works perfect but the AC button still does the same thing comes on with three blinks then shuts off... i checked the fusebox it's not blown. maybe ground wire.... any advice would be GREATLY APPRECIATED
Thanx in advance for any advice
Old Jun 8, 2006 | 01:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check to see if you have any DTC Codes and post them. That will help us figure out what is wrong!
BC
Old Jun 8, 2006 | 02:54 PM
BrentNY's Avatar
BrentNY
Hey Bill it sounds like my blinking light problem Solved with ensuring ground, replace 34 fuse and lo pressure sensor.
To Need Help W/air Condition
