Squeaky roof
Old Aug 28, 2001 | 01:00 AM
vette0202's Avatar
vette0202
Cruise-In I Veteran
Default Squeaky roof
My roof squeaks when I run over rough roads. Any ideas on fixing this?
Old Aug 28, 2001 | 01:10 AM
livinitup's Avatar
livinitup
Default Re: Squeaky roof (vette9898)
Hi: Mine began sqeaking suddenly one day and I sprayed WD-40 around the roof tie down area, or whatever you call those things. Anyway, it worked.
Old Aug 28, 2001 | 02:27 AM
BruceF's Avatar
BruceF
Try applying a thin coat of Silicone Dielectric grease to the weatherstripping. You should be doing this periodically to all of the weatherstripping anyway.
If that doesn't help, you will need to adjust the latches.
Old Aug 28, 2001 | 09:06 AM
Mark S.'s Avatar
Mark S.
Bruce's remedy should cure the situation.
Old Aug 28, 2001 | 09:13 AM
steve1173's Avatar
steve1173
Default Re: Squeaky roof (BruceF)
Where can I obtain some silicone dielectric grease, I went to my dealer & local parts store & neither had it. They recommended I use silicone spray instead.
Old Aug 28, 2001 | 09:29 AM
Mark S.'s Avatar
Mark S.
Default Re: Squeaky roof (steve1173)
You can dielectric grease just about anywhere (AutoZone, Twin B, Pep Boys)...but it is recommended that you use GM's dielectric grease (comes in a small tube, about $9 and lasts forever). Mid-America also sells it (3 tube package). Just take a little bit and rub is sparingly over all of your weatherstripping (with the top off) and remove the excess with a cloth...not only will it eliminate squeaks, but it will make your weatherstripping last a lot longer.
To Squeaky roof
