Ti exhaust??????
Old Jun 9, 2006 | 09:10 AM
MedChoice Tony's Avatar
MedChoice Tony
Default Ti exhaust??????
Hi, I am putting on a Ti exhaust thanks to a memeber here and was just wondering if I need to replace the gaskets? or anything else I should need to bolt these up.
Thanks in advance,
Tony P.
Old Jun 9, 2006 | 10:40 AM
C5XTASY's Avatar
C5XTASY
I always install new gaskets when replacing any part....cheap insurance.
Ed
Old Jun 9, 2006 | 01:22 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Ed
, but It is easy enough to replace later if you do find one that leaks thouigh.
Old Jun 9, 2006 | 02:00 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Because of the heat, the gaskets grow soft and often when you remove the exhaust from the car, your gasket will stick a bit. Recommend that you spend the $10-$15 and replace them. I have swapped my exhaust 4 times and each time I replaced the gaskets to save myself the headache of happening to replace them later. Your call, if you have very low miles you maybe able to get away with reusing them with little issues.
Micah
Old Jun 9, 2006 | 03:42 PM
MedChoice Tony
Ok thanks for the information....where can I get the gaskets and can I just use generic ones from say "NAPA"? Also, can someone let me know where they got theirs and if they know the part #?
Thanks,
Tony P.
Old Jun 9, 2006 | 03:56 PM
Meebix's Avatar
Meebix
Try Jegs.com. They sell almost everything.
Old Jun 9, 2006 | 03:58 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I have a wholesale account at GM, so I go there, but JEG's, ECKLERS, SUMMIT RACING all probably got what you need.
Old Jun 9, 2006 | 08:11 PM
MedChoice Tony
Thanks for the information....but what are the gaskets called as I was looking but found alot of gaskets online? Sorry but a little new to this!
Thanks,
Tony P.
Old Jun 9, 2006 | 10:48 PM
Laguna Blu's Avatar
Laguna Blu
I'm swapping out some Indy's for Ti's and I haven't heard about any gaskets. Do I need to bring them to The Vette Doctors?
Old Jun 10, 2006 | 12:30 PM
lone73's Avatar
lone73
What exactly is Ti exh and what does it do for you?
thanks
Old Jun 11, 2006 | 08:15 PM
MagRed04C5's Avatar
MagRed04C5
1) Made of Titanium instead of Painted Stainless Steel
2) A lot lighter in weight
3) Nice round tips instead of oval
4) Better flow
5) Hey, It's a Mod
Old Jun 23, 2006 | 04:09 PM
Laguna Blu's Avatar
Laguna Blu
Turns out that the gaskets were just fine and re-usable with some hi-temp silicone.
To Ti exhaust??????
