LC-1 ?, read out problems
Old Jun 9, 2006 | 11:24 AM
ivandrea's Avatar
ivandrea
Default LC-1 ?, read out problems
Installed the LC-1 and followed all the directions to a tee. After the start up procedure. The guage read out was between 3 and 9, at idle through load. Now the red LED indicator shows that it is at normal operation. I went throught the relearn calibration process and still the same issue. I did notice the when the clear shipping cap was installed from the source some of the anti-sieze lube was on the tip. Now I know it should be contaminet free so I cleaned it with alcohol wipe. Could this be the problem? Has anyone else had this issue? Please help.
