Replacing Fuel Filter...
Old Jun 10, 2006 | 12:05 AM
RED Coupe's Avatar
RED Coupe
Default Replacing Fuel Filter...
Are any special tools required in replacing the fuel filter on a 2001 Coupe? As always, thanks for the guidance.
Old Jun 10, 2006 | 12:25 AM
pawngod's Avatar
pawngod
they claim it needs a special tool but a tiny screwdriver can get it done just becareful not to break the plastic clip that holds it in
Old Jun 10, 2006 | 09:30 AM
RED Coupe's Avatar
RED Coupe
Thanks for the response and caution...
Old Jun 10, 2006 | 09:11 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
there is a special little plastic fitting that slips around the plastic fuel line and spreads the prongs inside the filter so you can pull the line out. the tech at coh said that some of the filters that come in have this little device in with the filter.
Old Jun 10, 2006 | 09:41 PM
djengr's Avatar
djengr
Although I have not removed a fuel line. There are fuel line tools available at autozone for about $7. I have seen them other places as well in the same price range.
Old Jun 10, 2006 | 10:42 PM
LoneStarFRC's Avatar
LoneStarFRC
Not too bad a job at all. I would strongly recommend you relieve the fuel pressure at the fuel rail unless you let it sit overnight to let the fuel pressure bleed down. I agree with the others, get the little set of fuel line disconnect tools. It's cheap. I have a set made by Lisle and I think I picked it up at Sears in the tool dept.
BTW, remember that your filter is also your fuel pressure regulator (built in) when you have the heart attack at seeing the price.
Old Jun 11, 2006 | 10:45 PM
RED Coupe's Avatar
RED Coupe
Thanks very much for the guidance...
Old Jun 12, 2006 | 10:47 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
FYI, the Vette does not use the normal donut style disconnects with the exception of the line going to the fuel rail. Just use the screwdriver carefully or even your fingers for the filter or the pump at the tank.
Old Jun 12, 2006 | 11:04 AM
c5chines's Avatar
c5chines
Default Fuel Filter Change...
I hope you have an easier time than I did. It's a PITA. There is not enough room to get a tool onto the line clips,if there is a too made for that. My parts store says there is not a tool for the plastic clips and demonstrated how to release the clips by hand, which works easily if you have some room. You need to disconnect the exhaust to gat access to the filter and even then, it's tight. The mounting tab on the filter prevents it from rotating enough to get to the clip tabs. I removed the mount tab and that made the job easier. I don't know about the cost of a filter for a 2001, I have a 97 and it was $13. Figure 2 hours total and a lot of patience.If the stars and planets align just right and you get lucky with the tabs,1 hour. If you had a fuel leak, you might want to rinse off the accumulated fuel from the underside of the tank shield when you arte done to get the smell off.Chuck.
Old Jun 13, 2006 | 08:02 PM
LoneStarFRC
Man, it sounds like you had a bad time there. It sounds like you may have an A4 and as I understand it, partial removal of the exhaust when changing the filter on cars with an auto trans is required. I know that on my MM6, it was pretty much a snap and no tail pipes were involved. I also had no problems getting to the clips. Glad you finally got it done.
Robert
Old Jun 13, 2006 | 08:57 PM
RED Coupe's Avatar
RED Coupe
Robert
This sounds more reassuring, I personally wouldn't attack this if it involved any exhaust system removal. Comforting to hear it's not that bad to replace on a 6speed. I haven't looked under there yet, will back the car onto a small set of ramps and look at it this week. I assume I can do this with the rear on the ramps....true?
Old Jun 13, 2006 | 10:29 PM
LoneStarFRC
You should have no problems, as long as you can get under the left rear side (in front of the wheel) to get to the filter. like Cajundude said, a couple of the lines can be released with your fingers by just squeezing and pulling apart. For the other one it's best to have a removal tool. BTW, you will have a little spillage from the fuel that's still in the filter and don't forget to be sure the fuel pressure has been released first.
Old Jun 13, 2006 | 10:35 PM
Cajundude's Avatar
Cajundude
Here are some pics if it helps.
Old Jun 13, 2006 | 10:39 PM
LoneStarFRC
You da man!
Old Jun 13, 2006 | 10:40 PM
RED Coupe's Avatar
RED Coupe
Excellent!!!! Thanks.
To Replacing Fuel Filter...
