Roll Cage Recommendations?
Old Aug 28, 2001 | 03:32 PM
nwong's Avatar
nwong
Default Roll Cage Recommendations?
Anyone have a manufacturer/installer in the So. Cal. area for a roll cage for a C5 coupe? Want to take my C5 to the track one of these days. Thanks!
Old Aug 28, 2001 | 09:20 PM
Mell's Avatar
Mell
Default Re: Roll Cage Recommendations? (nwong)
nwong
Here is a link to how I did my FRC with a DRM unit.
Did a Coupe the same way and it came out great.
http://tradezone.com/vette/rollbar.html
Mell
Old Aug 28, 2001 | 10:17 PM
davidfarmer's Avatar
davidfarmer
Default Re: Roll Cage Recommendations? (Mell)
Kirk makes a bolt/weld in cage that is SCCA legal (T1 club racing) and is relatively easy to put in by any competent mechanic with a welder. 205 823 6025
Old Aug 28, 2001 | 10:23 PM
Conv.WS6's Avatar
Conv.WS6
Default Re: Roll Cage Recommendations? (y2khardtop)
What kind of money for the Kirk SCCA Roll Cage?
Old Aug 29, 2001 | 12:56 PM
SilverStar's Avatar
SilverStar
Default Re: Roll Cage Recommendations? (Conv.WS6)
Mell
I'm really suprised that you didn't drop the tanks before welding. I had my bar installed and they did not drop the tanks as required; ended up melting some tubing and both tanks had to be replaced. It was a nightmare.
Old Aug 29, 2001 | 02:12 PM
Mell's Avatar
Mell
Default Re: Roll Cage Recommendations? (SilverStar)
SilverStar
I heliarced it and let it cool between welds. A lot easier then dropping the tanks. Any other type of welding could be a night mare as you indicated unless you drop the tanks.
The main concern is the vent line that runs through that brace.
Mell
To Roll Cage Recommendations?
