Help help help installed cam lost 40rwhp
Old Jun 12, 2006 | 10:41 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Originally Posted by connecticut
with the oil pump off, it's simple to see the dots ligned up, did you line up the dots prior to the pump install?
I think he said his friend did the install while he was out getting parts
pewter99's Avatar
pewter99
I think you may wanna get the tuning guys involved here in the other forum...
Old Jun 12, 2006 | 11:55 AM
N0TDADYS_98's Avatar
N0TDADYS_98
just posted in the tune section... i'm going to start tearing her back down tonight.. pull pump off and get the dots lined up first....
Old Jun 12, 2006 | 12:03 PM
pewter99's Avatar
pewter99
FWIW..I am sure if you called one of the tuners listed on the left they would be willing to offer sugestions..I know the guys at ECS are always willing to help...
Old Jun 12, 2006 | 12:05 PM
N0TDADYS_98
Thats an awesome idea. Thanks... this site rocks.
Old Jun 12, 2006 | 12:47 PM
pewter99's Avatar
pewter99
were here to help
we are also here to at you
Good luck
Old Jun 12, 2006 | 01:17 PM
vettenuts's Avatar
vettenuts
Since the o-ring on the oil pump is a pain, I would try to assess the dot alignment with the pump in place first, since you already have good oil pressure and breaking the o-ring seal puts it at risk again.
Old Jun 12, 2006 | 01:30 PM
N0TDADYS_98
does anyone have a picture of the gear/dot on the crank?
Old Jun 12, 2006 | 01:41 PM
John@SDPC's Avatar
0John@SDPC
Former Vendor
Here is one pic of the dot-to-dot.
First, definitely check the physical installation of the cam. Did you degre the cam. I would also confirm all of the valve train geometry. Make sure that all the rocker arms were installed correctly. Have you pulled the plugs? Do all the cylinders appear to be working similarly? Running on 7 cylinders will definitely hurt the power.
The AFR is definitely lean, and what exactly does "timing was put in place to get a good run out of it" mean? If you were experiencing serious knock and timing was significantly reduced, then you will have a subsequent significant reduction in power.
Old Jun 12, 2006 | 03:18 PM
BMG50's Avatar
BMG50
More pics
http://i6.tinypic.com/148dyr9.jpg
http://i6.tinypic.com/148ek9u.jpg
http://i5.tinypic.com/148em9w.jpg
look closely....hth
Old Jun 12, 2006 | 03:40 PM
N0TDADYS_98
short of "eye balling" it... is there a more exact way?
also there was some play in my LS2 chain... which direction should i turn the crank to tighten the chain and make sure all is ok? I want to cycle it one time over and make sure the dots line up yet again perfect... After i'm done with this.... there will be no question it's timing.
Old Jun 12, 2006 | 06:05 PM
vettenuts's Avatar
vettenuts
Rotate direction engine turns, the driver's side will stay tight. If you are off one tooth, you will know it. I would only pull the timing cover and verify, if all is well then don't pull the pump. If it is off by one tooth, you still don't need to pull the oil pump.
Old Jun 12, 2006 | 09:41 PM
  #33
N0TDADYS_98
Originally Posted by sqeznbi
Did you degree the cam?
sorry... but when you say degree the cam what do you mean? is that the same as the dots?
Old Jun 12, 2006 | 09:43 PM
  #34
N0TDADYS_98
I didn't install the pump and i want to make sure its done right so i bought a new o-ring... it's coming off.
what direction does the engine turn if i'm looking at the throttle body.
Old Jun 13, 2006 | 02:46 PM
  #35
John@SDPC's Avatar
0John@SDPC
Former Vendor
It is a process to ensure that the cam has been installed correctly.
Read this.
Old Jun 13, 2006 | 04:46 PM
  #36
feeder82's Avatar
feeder82
look at the valve springs are they installed at the correct height? could be coil binding
Old Jun 13, 2006 | 05:22 PM
  #37
vettenuts's Avatar
vettenuts
Clockwise.
Old Jun 13, 2006 | 06:26 PM
  #38
NSTG8R's Avatar
NSTG8R
not trying to be rude .. did you read up on doing a cam swap prior to doing it?
Old Jun 13, 2006 | 06:50 PM
  #39
N0TDADYS_98
ya i followed the directions on LS1howtodo.com which was very very helpful... and I swear I got the dots lined up... but it was at like 3am in the morning when we did it.. I should have turned it 720* before reassembling but it looked perfect.. i fell asleep last night.. so i'll tear back into it tonight... I will take a picture of the dots after the oil pump comes off. before any adjustments...
I'm not sure how the springs/valves could be off... top of spring is level with top of valve..
