climate control light out
Old Jun 12, 2006 | 05:01 PM
crazygn's Avatar
crazygn
Default climate control light out
My problem is that the light on the front of the climate control wont come on any more, but the heat and ac still works. what could this be and can it be fixed . the screen is blank.
Old Jun 12, 2006 | 11:39 PM
dhaynes508's Avatar
dhaynes508
Default hvac display not working
This is a very common problem.
It is generally caused by cold solder joints on some control resistors on one of the internal electronic control boards.
You can purchase a cheap replacement on E-bay. This is what I did.
If you want to try to repair your unit yourself try seaching this forum and you will find some very good step by step procedures.
Old Jun 12, 2006 | 11:49 PM
dhaynes508's Avatar
dhaynes508
Default repair instructions
try this for information to repair
http://www.regalgs.org/climate.htm
Good luck
Old Jun 13, 2006 | 12:14 AM
RichAshley-Black99's Avatar
RichAshley-Black99
I was going to repair mine but bought one off E BAYYYYYYYYY for 30 bucks works great
Old Jun 13, 2006 | 07:38 AM
rws.1's Avatar
rws.1
If the display has gone dim, It is mot likely that you have a loose solder joint.
If you are handy with soldering, you can fix it yourself.
Otherwise a CF member will do it for about $50.
David Ruberg aka Mandigital
digitalguy_1@charter.net
here's the post on how to fix yourself
http://forums.corvetteforum.com/show...post1554703174
To climate control light out
