Car is COMPLETELY dead
Old Jun 12, 2006 | 09:05 PM
nosilwop's Avatar
nosilwop
Acct suspended by request 27 June 2011
Default Car is COMPLETELY dead
So I drove my vette home on my lunch break today because I live close to work and I went inside for about 40 minutes. When I came back out, it was completely dead. I mean, when I put the key in, NOTHING happens. It won't turn over at all. The display doesn't even light up. My keyless entry doesn't work. I can't pop the hatch. I don't get it. It was perfectly fine on the drive home. No warning of anything being wrong. And then it just inexplicably dies?? Anyone have any insight?? I guess maybe I'm getting it towed to the dealer......
Old Jun 12, 2006 | 09:22 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Wait 5-10 mins. then go try it again. I have had something similar happen. The first time it happened, I disconnected the battery and it worked fine. When it happened again, I just waited. Did the interior lights go on? When you turned the key, was it completely dead? Check the codes. One of them may be a security code. Thats what mine threw. Good luck
Old Jun 12, 2006 | 09:45 PM
nosilwop's Avatar
nosilwop
It's been hours now and I've tried several times since. I'm not getting anything. I can't check the codes because the display does not come up.
Old Jun 12, 2006 | 10:03 PM
nosilwop's Avatar
nosilwop
just tried disconnecting and reconnecting the battery. still nothing. i'm starting to fear that it's not an electrical problem but something worse.....it doesn't make any sense to me that the battery would die so quickly for no apparent reason. i replaced it not that long ago.
Old Jun 12, 2006 | 10:11 PM
nosilwop's Avatar
nosilwop
oh well. can't really go without my car too much longer. guess i'm going to bend over, grab my ankles, and have it towed to the dealer......
Old Jun 12, 2006 | 11:08 PM
Dave68's Avatar
Dave68
How old is your battery? If a cell or two dies, a battery can be so dead, a jump won't help start the car at all. I'd remove the battery and take it to your nearest auto parts store to have it tested.
Good luck.
Old Jun 13, 2006 | 01:53 PM
VetterGetIt's Avatar
VetterGetIt
And please let us know when you find out what in the hell it is.
Old Jun 13, 2006 | 02:18 PM
SpeedyZ's Avatar
SpeedyZ
A strap or post can break inside the battery and it will be completely dead instantly. Did you remove both cables and reinstall them? Sounds a lot like a bad battery cable connection or bad battery. If you have a volt meter remove both cables and check the voltage right on the battery posts.
Old Jun 13, 2006 | 02:21 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Man you give up too easy..its the battery..just replace it. If the dealer does it, you may get the nice leaky GM one that will destroy your PCM.
Same thing happened to me last month...this time I got Die hard Gold series with 5 year warranty for replacement.
Car started right up
Old Jun 13, 2006 | 02:39 PM
ST-rider's Avatar
ST-rider
same thing happened to me. drove to work in the morning and all was fine. went to leave for lunch and had no power at all.
it was the battery.
Old Jun 13, 2006 | 04:41 PM
chaase's Avatar
chaase
St. Jude Donor '12
Its the battery or the ground connection to the party
Old Jun 13, 2006 | 07:01 PM
N0TDADYS_98's Avatar
N0TDADYS_98
Good luck.
PLease dont' go to the dealer...
Old Jun 13, 2006 | 09:01 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Don't be so quick to exonerate your battery. The symptoms you've described are classic for a battery with a dead cell. Typically, everything's just fine and then BAM, dead as a door-nail....
Do a bit of diagnosis yourself before going to the dealer. Take the old battery out and and throw in a new one, it won't go to waste and you'll probably have just fixed it without having sex with the dealer...
Bob
Old Jun 14, 2006 | 10:36 AM
99 vett babycar's Avatar
99 vett babycar
buy a battery
Old Jun 14, 2006 | 09:43 PM
Joevette99's Avatar
Joevette99
Default Dead Battery
Last weekend I was in the staging lanes. Shut the car off. Turned it on 3 minutes later...DEAD..nothing.....same thing as you. It was the battery. Only thing it was one year old one. Had AAA deliver a battery to the track and raced later in the afternoon........
Good Luck.....
Old Jun 22, 2006 | 11:39 PM
dg144's Avatar
dg144
The same thing happened to me tonight, 03 vert, I took the battery out and will replace it tomorrow, we will see
Old Jun 23, 2006 | 01:21 AM
striper's Avatar
striper
The exact same thing happened to me this past weekend in my truck. Stopped to do an errand. I was out of the truck less than 2 minutes and the battery was completely dead when I went to restart it. Replaced the battery and the truck's been fine. BTW, the battery in my truck was the one out of my '03 Z06. I had put an Optima in the Vette.
To Car is COMPLETELY dead
