wide open problem
Old Jun 12, 2006 | 10:45 PM
bruston839's Avatar
bruston839
8th Gear
Default wide open problem
I have a 00 that i has some mods, Vararam,Lg Headers,x pipe , Borla stinger, stall converter (2700) shift kit w/ cooler 3:90 gears and tuned. When i come off the line wide open , the car hangs up in 2 nd gear and maxs the out rpm and studders i then have to back off the throttle ,let the car recover from the studder and i"m running again. i'm getting 1870 code. Please help me if you can.
Old Jun 12, 2006 | 11:00 PM
Mike Mercury's Avatar
Mike Mercury
you're hitting the rev limiter.
this step you listed "3:90 gears and tuned" was not done properly. The program changes are incomplete. The classic signs of incomplete programing (after a rear axle change on an A4) is the hitting of the rev limiter and setting the P1870 code.
Take the car back to the "tuner" and have then do it right this time.
