Diff whining when making tight turns
Old Jun 13, 2006 | 01:53 PM
FRC Shopper's Avatar
FRC Shopper
Default Diff whining when making tight turns
When I make sharp turns at very slow speeds (1-7 mph), I hear a whining/grinding noise from the rear diff of my '99 FRC. The previous owner of my car said he put Redline differential fluid in there. I'm assuming it requires either the GM diff additive or friction modifier?
I remember reading something about this in the FAQs, but I can't seem to find that thread.
Old Jun 13, 2006 | 02:03 PM
VetteDrmr's Avatar
VetteDrmr
Add a bottle of the GM differential additive and see if you problem goes away (my bet is it will).
HTH, and have a good one,
Mike
Old Jun 13, 2006 | 02:50 PM
FRC Shopper
I'll give that a try. Where on the differential case is the refill hole located?
Thanks!
Old Jun 13, 2006 | 03:36 PM
VetteDrmr's Avatar
VetteDrmr
Looking at the rear diff cover, slightly above halfway up on the right side. Takes a decent sized hex (allen wrench type) drive and 20 lb-ft.
Have a good one,
Mike
Old Jun 13, 2006 | 05:34 PM
FRC Shopper
Thanks a ton for your help!
To Diff whining when making tight turns
