What should I expect in return??
Old Jun 13, 2006 | 08:49 PM
SocalChvy's Avatar
SocalChvy
Default What should I expect in return??
2001 A4 stock corvette with 2.73 ratio. I plan to add CAI+long tube headers+3.43 gears+X-pipe(w/o cats)+dyno tune. What should I get to the rear wheels and est. 1/4 time??? Im about to spend some money and I wanna know is it worth while?
Old Jun 13, 2006 | 11:08 PM
willig72's Avatar
willig72
What you get to the rear wheels should be more HP
What you should get on the EST on the 1/4 time is a quicker time
Might think about lower gears if your driving habits would let you,
a good tune is money well spent also. Sounds like you starting in the right direction.
Old Jun 14, 2006 | 05:55 PM
SocalChvy's Avatar
SocalChvy
Thanks but you didn't answer any of my questions..
Old Jun 14, 2006 | 08:24 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
Ok maybe I can help a little,last month I had 3.73 gears and vig 2800 high stall converter put in. I already had long tubes and Halltech intake. DTE did the gear install and dyno tune. I put down 330rwhp 347 foot pounds torque. I haven't put it on the track yet, but is an all new car. You will love it, the gears make such a difference
To What should I expect in return??
