LS1 -> LS6 head swap ???
Old Jun 14, 2006 | 05:25 PM
rickkym's Avatar
rickkym
Default LS1 -> LS6 head swap ???
I've searched the forums and lstech... can't find the answer(s).
With a 97 LS1 going to used LS6 heads and a 224 cam, should I change my oil pump (43K miles) when I do the swap? I'm getting an LS2 timing chain, but the LS6 valve springs should be fine, right? And do I need better pushrods? Will I need longer/shorter pushrods? I'm trying to get a complete parts list.
Thanks!!
Old Jun 14, 2006 | 05:36 PM
zeevette's Avatar
zeevette
Thanks!!
Change to an LS6 (at least) oil pump, and replace the stock LS6 valvesprings.(with quality aftermarket) They've been known to fail, and ruin engines, so cheap insurance. Pushrods are known problem areas as well, so get new hardened PRs, in stock 7.4 length. Also upgrade to a 2001-up intake manifold and TB, which will require a rework of your older PCV setup.
Old Jun 14, 2006 | 06:08 PM
N0TDADYS_98's Avatar
N0TDADYS_98
your oil pump like mine is **** to failure.. replace with an LS6 oil pump... several companies offer ported pumps to flow more oil.
Old Jun 14, 2006 | 07:16 PM
zeevette's Avatar
zeevette
Actually, most of those are just mildly reworked stock LS6 pumps, and not proven to improve overall flow. Some guys have reported lower pressure with so-called "blue printed" oil pumps, but I don't know what the truth of the matter may be.
Old Jun 14, 2006 | 08:22 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
add new center bolt valve covers/bolts/gaskets to the list, 97/8 use perimeter bolt covers
Old Jun 14, 2006 | 08:42 PM
RED99's Avatar
RED99
Get a LS4 Oil Pump from Fred Beans. They are less than $60, unless they went up. They are suppose to flow about 30% more oil. Also get a new O-ring too no matter what pump you choose, because the pump doesn't come with one.
You can get a new set of LS6 Valve springs for under $70. The Better Comp Cam 918's are a little more than double that. These are single valve springs.
IMO, I don't think the hardened pushrods are that necassary until you start running double valve springs with way more spring pressure.
Old Jun 14, 2006 | 08:53 PM
fdxpilot's Avatar
fdxpilot
Actually, the "224 cam" doesn't tell us much, as depending on you lobe profile, you lift could be anything from .540-590. If your lift is much more than .550, you will need something better than the LS6 springs.
To LS1 -> LS6 head swap ???
