Starter removal tips ?
Old Jun 13, 2006 | 10:39 PM
VetteDawg's Avatar
VetteDawg
Default Starter removal tips ?
Anyone have a 'how to' for removing the starter?
Old Jun 14, 2006 | 08:01 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
ttt
Old Jun 14, 2006 | 08:19 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
LT's or stock manifolds? there's 2 bolts and a few wires
Old Jun 14, 2006 | 09:22 AM
HP_Addict's Avatar
HP_Addict
Step 1: Remove the 2 bolts.
Step 2: Slide starter forward
Step 3: Disconnect wires.(Be sure to disconnect the battery first)
Step 4: Remove from car.
Nothing to it, except there is not much room to work under there. Longtubes will make it tougher.
Old Jun 14, 2006 | 09:15 PM
VetteDawg's Avatar
VetteDawg
Thanks. Pretty straight forward then. I'm stock, no long tubes.
I assume I can use regular tools (nothing special).
Late this winter we had to change my son's on his '92 Mustang 5.0 - unbelievable PITA.
I may want to change my battery wires to switch to top mounting while I'm at it.
The problem is: the car is not starting as quickly as it used to. sometimes it cranks for 5 seconds before it starts...sometimes I have to try a second time...sometimes it's only an extra second or two...sometimes it starts right up.
The battery is brand new and good.
Doesn't seem to be a fuel flow issue.
19,500 mi on my Y2k.
To Starter removal tips ?
