TPIS header install help??
Old Jun 15, 2006 | 12:03 PM
brandtdavis's Avatar
brandtdavis
Default TPIS header install help??
I have a 97. Halltech Stinger and Borla stingers.
I just purchased a set of used (what I am told are TPIS) headers. I am beginning the install this weekend. Going to do all the work myself. Planning to go catless for now.
Here is install checklist for now.
1. Borla X pipe
2. New exhaust manifold gasket set.
3. Heat resistant material (like Koolsox).
4. 2 cat replacement pipes from local exhaust shop.
5. 2 Band clamps
6. O2 extension cable???
7. O2 sims ???
Questions
1. Do I need new exhaust studs?
2. What are the best exhaust gaskets?
3. Will I need O2 extension cables with TPISs
4. What exactly will happen if I don't have the O2 sims installed and can't wait to drive it.
Thanks for any help or suggestions.
Brandt
brandtdavis@yahoo.com
Old Jun 15, 2006 | 02:37 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Questions
No..
I used the existing ones...or you can get new ones from the dealer..your choice
I didn't..I kept my O2 sensors..evetually had them turned off after the CATs were gutted
It will throw some codes....thats about it
Have fun
Old Jun 15, 2006 | 02:38 PM
pewter99's Avatar
pewter99
oh BTW...no cats...you can't start it up and idle in your garage very long
Old Jun 16, 2006 | 11:28 AM
brandtdavis
I read that my car will run lean.
My thoughts:
The headers will allow the exhaust to exit the chamber once the valves open. Thus letting more fresh air enter the chamber causing it to run lean. But...won't my MAF read the extra incoming air and compensate the fuel. It works with dry Nos systems.
Why can't I run it in my garage?? smell, noise, angry neighbors??
Old Jun 16, 2006 | 03:05 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Carbon Monoxide kills, w/out cats your eyes will water after 2 minutes
Old Jun 16, 2006 | 04:19 PM
pewter99's Avatar
pewter99
yeah..pretty much
Old Jun 16, 2006 | 04:20 PM
pewter99's Avatar
pewter99
[QUOTE=brandtdavis]I read that my car will run lean.
QUOTE]
actually headers may cause it to run rich....
Old Jun 17, 2006 | 09:31 AM
Greg00Coupe's Avatar
Greg00Coupe
It will run rich....... I have not had a tune done, need to do that. But what happens with mine is when I come to a stop and idle a little, maybe 15 seconds I get a code. Now if I clear the exhaust system, rev the engine to 1500 rpm or so several times no problem. Obviously don't want to have to do that at every stop light.
Old Jun 17, 2006 | 10:58 AM
NSTG8R's Avatar
NSTG8R
[QUOTE=pewter99]
QUOTE]
although on the rare occation .. it will go rich ..
Old Jun 17, 2006 | 11:49 AM
brandtdavis
Why would it go rich. Won't the PCM find the correct value on the look up tables after 100-200 miles??
Old Jun 17, 2006 | 12:16 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Not really. Stock tunes are conservatively rich anyway. Mine is really rich after adding headers.....so I only gained 9 rwhp from the long tubes. A tune is next on my agenda....I expect to gain nearly 20 more rwhp from that. It's fine to slap them on there and see what happens.....certainly ain't gonna hurt anything. All cars are different.....some are fine without a re-tune. But to get the most out of them you'll really most likely need a tune.
Old Jun 17, 2006 | 10:15 PM
brandtdavis
Well I got the H pipe and stock manifolds off today. Took pretty much all day just doing it myself. I am wrapping things in high temp. insulation tomorrow and dropping the LTs in hopefully. Everything went smoothly so far following the instructions I found on ls1howto. thanks for all the advice and help. Sounds like I might have to make a trip up to Lingenfelter soon...
Old Jun 19, 2006 | 12:01 PM
brandtdavis
I got the passenger side on with little problem. I'm having trouble with the driver's side though. It says to bring it up from the bottom. I don't know if the TPISs will go up from the bottom. I don't have my car high enough yet so I'm going to try that. I tried taking it in from the top but it hits the big alternator bracket and gets stuck on the braided fuel lines. It gets to a point where the tab looks like it is going to hit my oil filter.
Any help??
thanks
Brandt
To TPIS header install help??
