CCW Wheel size?
Old Jun 16, 2006 | 07:04 AM
dtmcnamara's Avatar
dtmcnamara
Default CCW Wheel size?
Ok I am looking at some CCW wheels and really am not sure waht style I want but I need to figure out what size?
I am looking to do 20's on the rear and 19's up front. Whats the best width for a 99 C5?
Rear 20x10
Front 19x9
Also I am looking between the sp18, sp20 and the sp20a, anyone know if the C6 Z06 brake kit will fit behind all of these styles? If they dont I will not b getting the rims, THANKS
ALSO WHATS THE BEST TIRES SIZE FOR THE RIM SIZES THANKS
Old Jun 16, 2006 | 07:21 AM
AU N EGL's Avatar
AU N EGL
The C6Z brakes only fit under the Corsar Motorsports wheel do to the required offset of the wheel. The Motorsports wheel only comes in 18"
Call John or Chip for Info
Old Jun 16, 2006 | 01:32 PM
gorillavet's Avatar
gorillavet
On a C5 you don't want to get much larger than 19 inch. Poor stopping performance and much increased weight. For what it is worth the rotors for the C6Z06 weight a TON compaired to C5 rotors.
Old Jun 16, 2006 | 06:14 PM
dtmcnamara's Avatar
dtmcnamara
So ONLY the Corsar Motorsports wheels will fit with the C6Z brake setup? Damn, you got any pics of these wheels, and a number/website I can go to and order them? THANKS
Old Jun 16, 2006 | 06:27 PM
AU N EGL's Avatar
AU N EGL
http://www.ccwheel.com
Look at the yellow ZO6 on the home page.
I think they are only made in 18x10, 18x11 and 18x12
Old Jun 16, 2006 | 07:47 PM
gothamZ06's Avatar
gothamZ06
I just recieved my custom CCW SP500s from John, they are designed to fit over the C6 Z06 brakes. Now if I could only figure out how to get the brake lines on the calipers...
I have the wheels sitting here, as soon as the calipers are on I will post pictures.
-N
Old Jun 17, 2006 | 12:02 PM
dtmcnamara's Avatar
dtmcnamara
You know what the price of these wheels are? They arent really the style of wheel I was looking at, but they might works.
Also....would the sp20 or sp20a wheel work with a wheel space inserted?
Old Jun 17, 2006 | 12:10 PM
AU N EGL's Avatar
AU N EGL
To use wheel spacers you will need longer studs and open ended lug nuts. I use a 3/8" stud on the rear wheels so I can use a 18x13" rim
I have the longer studs on front too: CCW Classic Track pictures 18x12" front
Price of the Motorsports wheels are $25-$2700
Old Jun 17, 2006 | 12:21 PM
gothamZ06's Avatar
gothamZ06
See my post above.
I have the first set of Big Brake Kit Wheels from CCW. If they fit right John will make any style you want in the right kit.
Right now, NONE of those wheels in the standard design will fit, except for maybe the classics (still need spacers). If you run a spacer you will need 1" in the rear and like 1/2 - 3/4" in the front -- in short your wheels will stick out like crazy!
-G
Old Jun 17, 2006 | 01:40 PM
racewheel's Avatar
0racewheel
Former Vendor
the 19x9 / 20x10 combo could be made to clear the c6z brakes, as long as you didint go bigger than 285 30 20 on the rear tire, a more practical setup wpuld be the new 18x9.5/19x11 (1" smaller lips)combo we just finished up which would let you use the 305 30 19 tire out back
john
Old Jun 17, 2006 | 11:48 PM
98C5RT's Avatar
98C5RT
From: Somewhere between the Red and the Rio Republic of Texas
I have 19's all round but have not touched the brake set-up yet. Just keep in mind, the bigger the wheel the more expensive the tire. I forked over almost $1,800 for two rear tires.
Old Jun 18, 2006 | 12:20 AM
Bret01Z06's Avatar
Bret01Z06
When I ordered my CCW's I talked to John about the C6 Z06 brakes. They will clear but you must give up the larger lips and run a 1'-front and 2'-rear. I decided to go with the bigger lips and will get the rotors/brackets for the C6 Z51.
Old Jun 18, 2006 | 07:32 AM
gothamZ06's Avatar
gothamZ06
john
Big thanks to John for getting these wheels out to me! I promise pix with new wheels and C6 Z06 brakes by Monday. John and his crew are always a class act! This is the second set of wheels I've bought from CCW and wouldn't hesitate to do it again!
Old Jun 19, 2006 | 02:23 PM
Bret01Z06's Avatar
Bret01Z06
Any update on this. I want to see some pictures. I almost went with SP500's designed to clear big brakes.
Old Jun 19, 2006 | 04:53 PM
GAS's Avatar
GAS
I have a set of HRE wheels that bolt right on over my STOPTECH bbk. 19's in front and 20's in the rear. Car is lowered and you occasionally bottom out with this setup but it looks nice. I just got a set of the CCW Corsairs for track days and they go over the bbk with lots of room to spare. To run the CCW Classics 18x11 front and 18x11 rear I have to run 1/2 inch spacers to clear the bbk.
Old Jun 19, 2006 | 05:51 PM
gothamZ06's Avatar
gothamZ06
Sorry I got stuck in the office today and didn't get a chance to get to the car. Tomorrow I will force myself to test fit and take some pictures.
I did, however, learn that LAPD makes modified Goodridge brake lines that will BOLT-IN directly to the C6 Z06 calipers!
-G
To CCW Wheel size?
