What are the differences in power between long tubes?
Old Jun 17, 2006 | 04:31 PM
MUKAK's Avatar
MUKAK
You guys forget about Dynotechs......
On my 97 with Vararam and Dynotech Lts, and Borla straight pipes I gained 47RWHP and 52RWTQ
Dynotechs are pretty much same headers setup as the LG just without a 3 inch merge connector.
and KOOKS by the way are not 100$ stainless Steel..... only the primary tubes are SS the rest of the system is ALUMINIZED STEEL fo some sort.......
I never heard a Problem with DYNOTECH headers, FIT, FINISH, QUALITY is second to none. And Dynotech make headers for a lot of applications not just a C5/C6.
LET THE HEADER WARS BEGIN.............
Old Jun 17, 2006 | 05:27 PM
vetteuphoria's Avatar
vetteuphoria
Originally Posted by LT-4 CE
I went though this same thought process about 3 months ago. I went with the LG Street Series (header, x-pipe, and high flow cat). If you are at all on a budget, I don't think this set up could be beat. The headers are stainless. The kit added 30RWHP to my Z06 and was under $1300 shipped to my door.
If you don't mind my asking, where did you locate such a good deal?
Must admit, those numbers posted for American Racing and Dynatech are very impressive.
Old Jun 17, 2006 | 10:48 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I ordered directly from LG.
They were offering the street series kit for $999. Add $200 for the cats and $38 for gaskets.
Old Jun 17, 2006 | 11:18 PM
vetteuphoria
That's the best deal I've seen on LG's yet . Thanks for the reply.
Hope I didn't go off too far from your original post Shooter
Old Jun 17, 2006 | 11:27 PM
Chuck01's Avatar
Chuck01
Default Headers
LG has a special right now on the Street Series with cats under $1,200.00 shipped to your door. Great deal, but you have until July 4, 2006. They have it posted in one of these sections...
Old Jun 18, 2006 | 01:45 PM
Billf6531's Avatar
Billf6531
Well, since we're on the topic of headers, who manufactures an 1 3/4" header system that is flange bolted, front to rear? Long or short?
Not slip fit / muffler clamp technology.
I'd like to continue to use my Z06 Titanium mufflers.
Old Jun 18, 2006 | 04:45 PM
Camaroguy22's Avatar
Camaroguy22
If the longtubes have the same size primaries and collectors and are both coated or both uncoated will perform the same. Buying Brand A or Brand B will not matter in the performance dept. What you should be concerned about is ease of install, thickness of the flanges, how well others have said they will last. (Note: just becuase somebody said "oh they haven't rusted on my car for x amount of years" doesn't mean they will last that long for your application.) You need to pay attention to your climate vs theirs. Ceramic coated longtubes in the climate I am in only last a little over a year before they start to flake and rust. Where as in AZ they will last significantly longer.
