Temp is HOT...need help...
Old Jun 16, 2006 | 06:15 PM
1999 Vette's Avatar
1999 Vette
Default Temp is HOT...need help...
Its in the mid 80s now and I was running the air when I noticed that the coolant temp went over 250 degrees...Ofcourse, I turned off the air and the temp started going down. I was driving in mild traffic...car was moving along....
Car IS modified...220-224 cam stage 2 Heads, LTHrs, 3.90s on A4 99
Is this normal? Is this due to the Mods?
Any suggestions on how I can drive with the air on and keep the temp lower?
Thanks!!!!
Old Jun 16, 2006 | 06:30 PM
AU N EGL's Avatar
AU N EGL
take a high pressure air hose and blow out all the Micky D bags, soda straws, grass, dirt, sand and Miatas that got sucked up into the radiators.
If you can take the radiator cowling off on top do that too and blow out all that stuff.
You will be suppresied at how much gets up there in a little time. Plus and the sand and dirt you dont see.
Old Jun 16, 2006 | 06:42 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
1000000000000000000000000000000000% you will s*** a brick when you see how much crap is in there
Old Jun 16, 2006 | 08:07 PM
Sportsdude's Avatar
Sportsdude
I'm looking at getting a Dewitt rad to see if it will keep my temperature down.
Old Jun 16, 2006 | 11:09 PM
ValleyZ06's Avatar
ValleyZ06
I cleaned my radiator (and a/c condenser) with a high pressure hose (took radiator cover off) a few weeks ago and went from temps of around 228-235 to 198-205. Simple, easy fix. The ambient temps in South Texas range from 95 to 103. Try this before throwing money at the problem.
To Temp is HOT...need help...
