How Hot Does Your Vette Run?
Old Jun 17, 2006 | 12:13 AM
nyurdrms's Avatar
nyurdrms
Default How Hot Does Your Vette Run?
I was hitting 250 after 10-15 minutes of driving all last week. Took it to Chevy and spent 1200 replacing fans, fuses, radiator, water pump..etc. Now sticking around 215-225....is this about average? After that much cash (at employee cost) it better be running average. But what is average? Please help!!!
Thanks all,
00' Coupe
Old Jun 17, 2006 | 12:23 AM
allmee's Avatar
allmee
Thanks all,
00' Coupe
225-230 is about right in traffic. At that temp fans will come on and temp should drop pretty rapidly. Then fans will go off and temp will shoot up again. This is the cycle in traffic driving. You should be at about 190 or so at highway speeds.
Old Jun 17, 2006 | 12:42 AM
ALLEGRO's Avatar
ALLEGRO
It will actually runs cooler with the AC on !
The fans run all the time with the AC on so you don't get that spike in temp when sitting idle in traffic.
Mine runs about 192 on the highway and up to 235 in traffic. It really bugs me when it gets that high so often I have the top off, windows down and the air on !
Old Jun 17, 2006 | 01:12 AM
allmee's Avatar
allmee
I purchased one of those fan controller units from Mid America. I never installed it, it has this type of probe that needs to be inserted between the radiator fins to monitor the temp. I did'nt like that type of application so I never used it. I t sits in the garage in the box it came in!
Old Jun 17, 2006 | 01:47 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
That seems about right for a stock setup as this is what I usually saw in San Antonio. I went FI with a Dewitts and now when I get stuck in traffice I have only seen 215 in the 100+ degree days we see here and this is nothing to worry about as the stocker was made to run hot for emission reasons
Old Jun 17, 2006 | 08:21 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I had my fans reprogrammed when I had the headers/tune done. The car runs 194 pretty much all the time.
Old Jun 17, 2006 | 08:25 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Exacly my experience with mine
Old Jun 17, 2006 | 09:05 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Jun 17, 2006 | 09:43 AM
Mike94ZLT1's Avatar
Mike94ZLT1
I never see higher than 200-205
Old Jun 17, 2006 | 09:56 AM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
192-198 on the highway. 220-230 stuck in Dallas traffic. This is with 100% stock cooling and regular cleaning of radiator debris.
Old Jun 17, 2006 | 12:17 PM
C5Jimmy's Avatar
C5Jimmy
Thanks all,
00' Coupe
Wow!
190-192 on the highway, about 225 max in traffic, not moving
Oil never above 215
Old Jun 17, 2006 | 01:27 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old Jun 17, 2006 | 01:31 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
238 water 258 oil WOT at the track redlined all the time for 20 minutes.
Old Jun 17, 2006 | 11:32 PM
MadMaxZ06's Avatar
MadMaxZ06
Thanks all,
00' Coupe
When you say 250, are you talking about oil or coolant temperature?
In 90 degree weather, my car's engine oil can easily get up to 230 if I'm having fun with it (read keeping revs above 3,000 and stabbing it towards redline as the highway clears) My coolant temperature will run between 190 and 200 when running highway speeds. If I stop, or get stuck in heavy traffic, my coolant temps will rise to 225 then drop quickly once I get moving again.
- Max
Old Jun 17, 2006 | 11:47 PM
GeorgeB's Avatar
GeorgeB
Old Jun 18, 2006 | 01:17 AM
ECV-Tony's Avatar
ECV-Tony
Thanks all,
00' Coupe
Your temps sound fine, if you live in a hot weather area. When I see those temps in mine it is usually in summer while driving in town. As soon as I get to the freeway or open road it drops to 190 quickly. I've seen the same temp behavior on my '99 coupe (sold) and now my '04 Z06. I had a stock thermostat in both.
I'm sure you have checked fluid levels and insured there are no leaks in your cooling system? It could be as easy as replacing the radiator reservoir cap too. Maybe replace the thermostat?
I do my own coolant changes and like that I know what is going in my radiator. Hope this helps. I know when something with my car isn't right...I don't feel right. Good Luck.
Old Jun 18, 2006 | 11:40 PM
debmwb's Avatar
debmwb
Originally Posted by Cajundude
Why does everyone ***** over the fact that the C5 runs cooler with the A/C on? Mine sure does. Turning on the A/C actually changes when the fans come on...essentially keeping the temperature lower than with the A/C off. It does rob power though, but....
To How Hot Does Your Vette Run?
Old Jun 18, 2006 | 11:52 PM
Tigershark3's Avatar
Tigershark3
Just flushed the coolant and replaced with Dex Cool and distilled water. 190 on the highway and 210-215 in traffic.
Old Jun 19, 2006 | 01:51 AM
MeekRN's Avatar
MeekRN
driving up hills passing trucks in arizona during the summer... 193 with AC on. however i had removed the plastic rock sheild under the car all 3 pieces and had problems with high temp even on flat ground, apperantly the shield ducts air up to the radiator also... i put it back on and temps back to 193 steady. with the ac on there is an extra fan that turns on which keeps the water cooler.
Old Jun 19, 2006 | 05:40 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
180* MAX..... I have my fan temps set at 180* on 170* off I also have a Meizere EWP and 160* Stat
90* WOT won't even budge the temp gauge
