question about stock MAF screen
Old Aug 29, 2001 | 12:33 PM
Mike Siska's Avatar
Mike Siska
Default question about stock MAF screen
I have a vortex cold air box. I know that the MAF screen is still on. What would or will happen if I remove it? :confused: Right now, I have stronger acceleration (SOTP) on the top end.
Old Aug 29, 2001 | 12:47 PM
intel55's Avatar
intel55
Default Re: question about stock MAF screen (Mike Siska)
I doubt you wil "feel" anything, but GM did remove the screen on the new 2002 LS6 Z06. Myabe from a smoother airflow and better breathing you pick up a few ponies.
:cheers:
Old Aug 29, 2001 | 06:28 PM
99 The Hard Way's Avatar
99 The Hard Way
I have to vortex on my 98 & when I removed the screen, I could tell a difference. Some cars slow down. I think some like it & some don't. It's always a debate on here, though! If you want to take a chance, I say try it. Its up to you.
Old Aug 29, 2001 | 06:38 PM
CMilVette's Avatar
CMilVette
I have the Vortex and removed the screen on my 2000. I have had no problems at all......My car liked the mod, but the gains are minimal. :cheers:
Old Aug 29, 2001 | 07:50 PM
imxz28's Avatar
imxz28
Default Re: question about stock MAF screen (CMilVette)
Took mine off..... There is not SOP feel but you can hear that good old moan better. Kinda like the old 4 barrel carbs kicking in !! I loved that sound. Only in the LS1 TB, it sounds even meaner
Old Aug 29, 2001 | 08:03 PM
WHY2KRAG's Avatar
WHY2KRAG
Default Re: question about stock MAF screen (imxz28)
Mine was removed when I installed the Halltech. I can only say IMHO a major difference in sound just like the old AFB carbs without any aircleaner on. Say a 57 Buick 364 cid carter AFB no air filter WOT waht a sucker sound. :seeya
Old Aug 29, 2001 | 08:13 PM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
Default Re: question about stock MAF screen (WHY2KRAG)
I've got the RM Racing Twin Flow on my '98. Should I remove the screen? If I do, can I put it back on or this a permanent mod? What's holding that little sucker in there? I didn't really look that closely at it when I installed the Twin Flow.
Dave
Old Aug 29, 2001 | 09:26 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: question about stock MAF screen (Drop_Top_Dave)
Dave
Dave I removed mine on my 99. it did not hurt anything..and SOP seemed better... it screen seems to have been pressed in.. I ruined mine taking it out.. I stuck a wide blade screw driver through it.. and pryed it out..
you can take it out without destroying it but tapping it out from the inside using a piece of woor or a rubber mallet..
Old Aug 29, 2001 | 11:59 PM
Drop_Top_Dave
Kid Rock Fan
Default Re: question about stock MAF screen (Evil-Twin)
Hmmmm, thanks for the tip. This is my kinda mod...FREE!! :D
Old Aug 30, 2001 | 02:16 PM
C5Longhorn's Avatar
C5Longhorn
Drop Top Dave,
My opinion is that I wouldn't remove it. I've heard of individuals with Twin flow intakes getting surging from removing the MAF screen due to turbulent air. I don't have any personal experience with this since I have a Halltech, but just thought I would give my $.02.
Old Aug 30, 2001 | 02:28 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
IMO dont remove the screen if you want to try some bigger maf ends with no screen that might work. I had a 97 with a twin flow and no screen and got lean codes P0171 and P0174 as soon as I switched over to the Vortex no codes ever. :cheers:
Old Aug 30, 2001 | 04:43 PM
Closer_2001's Avatar
Closer_2001
Take it out-Throttle Response is awesome, pulls very hard!!
To question about stock MAF screen
