Injector question
Old Jun 17, 2006 | 07:20 AM
Blow Torch's Avatar
Blow Torch
Default Injector question
I noticed one of the small plastic (I think) disc on the bottom of one of my injectors is broken in half. (Only 1/2 is remaining attached to the injector.) What issues will this cause, and what can I do to repair it?
Old Jun 17, 2006 | 11:47 AM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Are you talking about the orings?
How about a picture of what you are talking about.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Jun 17, 2006 | 12:20 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
No, there is a small disc at the bottom of injectors that distribute the fuel spray. If one injector looks different from all the others, yes, absoultetly I'd replace it. Just look in the for-sale section, many folks replace the stock units with aftermarket items, so no need to go to the dealer.
Old Jun 17, 2006 | 01:19 PM
Blow Torch's Avatar
Blow Torch
It's not the actual tiny metal disc in the tip of the injector, it's a plastic looking disc located at the o-ring.
I don't have the injectors out rignt now, but if I need to, I'll pull them back out and get a photo.
Old Jun 17, 2006 | 03:23 PM
BLOWNZO6's Avatar
BLOWNZO6
If the oring seals in the head correctly you are probably fine.
I still have my stock set of injectors here, I will look at them and see if I can tell what you are talking about.
Nick
To Injector question
