Can't Hold Tire Pressure
Old Jun 17, 2006 | 03:28 PM
axikowboy's Avatar
axikowboy
Default Can't Hold Tire Pressure
Noticed I was losing pressure on the way home, so I had the store that mounted them the first time redo it. The next day I look and see that the tire looks low again, so I take it to the dealer and let them do it. Seemed ok for about a week. Dropped off at the dealer for another problem, picked it back up, tire is low again.
What can I have them do, I am assuming it is just a matter of them not puting the sensor, etc. in properly. The other three tires are holding pressure just fine. Sensor is still reading properly. Any suggestions?
Old Jun 17, 2006 | 04:10 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The tire needs to come off and be submerged in a tank of water to find out where the leak is coming from.
Old Jun 17, 2006 | 04:31 PM
c5freak's Avatar
c5freak
It may be the stem o-ring on the sensor.
Did you get new ones when they remounted the sensors?
A tank of water will tell you where it is for sure.
Al.
Old Jun 17, 2006 | 06:50 PM
LoneStarFRC's Avatar
LoneStarFRC
Suggestion: Re-torque the valve stem nut. Easy does it though. The nuts are aluminum so the correct torque is important.
HTH,
Robert
Old Jun 17, 2006 | 10:05 PM
Wisdom's Avatar
Wisdom
I had a tire that leaked for a week and I couldn't find a nail anywhere. Finally I looked at the vavle stem nut and noticed that the leaky one was much looser than the good ones. A quick twist with the wrench fixed that problem. Was careful to not overtighten too (don't own any crow's feet yet).
- Wisdom
Old Jun 17, 2006 | 10:14 PM
LoneStarFRC
- Wisdom
A deep 6 point socket works well.
Old Jun 18, 2006 | 08:40 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
agreed...........
Old Jun 18, 2006 | 10:09 AM
danberry's Avatar
danberry
Also check valve stem cap...if aftermarket see that it isn't leaking there......real soapy water will check that and the stem for leaks without taking tire(rim) off of car....will blow bubble or bubbles at leak..........Had that happen...little o-ring in cap got mashed and would push down on valve core when installed.........
Old Jun 18, 2006 | 10:31 AM
mrm1149's Avatar
mrm1149
Yep, had that one too!
Old Jun 18, 2006 | 12:16 PM
stevettenj's Avatar
stevettenj
I had the same problem a few weks ago. Brought the car back and had them dismount tire. Tech found that the wheel where the tire bead sits was not clean. They cleaned it up with a scotch bright pad. Also. have them to apply bead sealer.
Old Jun 18, 2006 | 01:02 PM
DeeGee's Avatar
DeeGee
The problem I had was a balance weight pinching the bead. caused a slow leak. Try a little dish washing liquid around the weight. May be one on the inside too.
Old Jun 20, 2006 | 10:20 PM
LoneStarFRC
Since you brought up the bead sealing issue, I thought I would share an experience I too had.
About three years ago I kept having the slow loss-of-air problem at one wheel. Some soap bubbles appeared at one spot along the bead at one place. After removing the tire I found a small bar-code sticker on the bead of the tire that was placed there by the manufacturer. Although small (about 3/4" x 1"), and made of thin plastic, it was all it took to create a very slow leak.
HTH
Old Jun 20, 2006 | 11:35 PM
Taxin's Avatar
Taxin
St. Jude Donor '06
Default leak
Al.
Old Jun 21, 2006 | 11:33 AM
j99vette's Avatar
j99vette
if you have aftermarket caps check to see if it has an o ring in it because sometimes it comes loose and then when you tighten it is presses on the valve stem. also i had a set of z07 rims and new kdw2s put on and when i went to pick it up i found that one tire was leaking. it was the o ring for the tps. good luck
To Can't Hold Tire Pressure
