HELP!! immediately on lowering front!!!
Old Jun 17, 2006 | 03:57 PM
c5vette_dallas's Avatar
c5vette_dallas
Default HELP!! immediately on lowering front!!!
i have lowered the rear and stuck in the shop til i can get the front done..how do i take the tension off the bolt..i have new bushings so i will be taking it all apart!!! help!!
Old Jun 17, 2006 | 04:30 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I'm not sure exactly what process you are using. But, you can place a fllor jack under the end of the front leaf spring. Put something b/w the jack and the spring, say a piece of wood, and then jack the spring up. That will take pressure off the bushing so you can turn it. Also spray the bolt with some lubricant as they can strip rather easily.
Old Jun 17, 2006 | 06:07 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
860-989-8972 if you still need help
Old Jun 17, 2006 | 09:06 PM
c5vette_dallas
thank you sooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooo o much..i am now home minus a swaybar (my fault)... thanx steve for all ur help..i would of had a sh***y weekend.. but now my vette is lowered!!
To HELP!! immediately on lowering front!!!
