What's your tire pressure?
Old Aug 29, 2001 | 01:58 PM
CarolinaC5's Avatar
CarolinaC5
Default What's your tire pressure?
Just wondering what you keep your tire pressure at for daily driving. Do you use the same pressure up front as in the rear?
Old Aug 29, 2001 | 02:07 PM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: What's your tire pressure? (CarolinaC5)
30 psi all around. :yesnod: :yesnod: :cheers:
Old Aug 29, 2001 | 02:10 PM
VettesRule's Avatar
VettesRule
30 psi cold all around. It is very smooth with that pressure.
[Modified by VettesRule, 12:26 PM 8/29/2001]
[Modified by VettesRule, 12:27 PM 8/29/2001]
Old Aug 29, 2001 | 02:18 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
after the tires are heated up .. after five minutes of driving I check to see that they are at 30 psi... That is a Hot reading ..... this number fluctuates because of road surface temps... Black top in the summer can get to 160 degrees... it will effect your tire presser..so I adjust the temp.. on a season level.. 25/25 psi cold in the summer.. 29/30 in the colder months.. to achieve a 30 psi at run temps.. I have 37000 miles on my original run flats.. 3/32 in the back/ 4/32 in the front.. Ill get 40,000 miles out of these tire.. and they are even all the way across.. the center tread is 3/32 the outside tread is 3/32
Old Aug 29, 2001 | 02:26 PM
Tom/99's Avatar
Tom/99
I have been running 30 psi all around. At 10,000 miles they show no wear. :chevy
Old Aug 29, 2001 | 03:58 PM
c5rose's Avatar
c5rose
Ever notice the pressure recommendations are different on the tires versus the sticker in the door jam (forgive my ignorance, as I know there is a technical name for this sticker).
I THINK the tires say 37, which is what I filled them to after getting it out of winter storage last spring. My DIC started going nuts:
LF HIGH PRESSURE *blink, blink, blink* RR HIGH PRESSURE *blink, etc.*
30 is what I keep 'em at.
Old Aug 29, 2001 | 04:13 PM
BruceF's Avatar
BruceF
Default Re: What's your tire pressure? (c5rose)
The pressure listed on the tires is the Maximum pressure you can run them at. The sticker on the Driver's Door is what you should go by.
Old Aug 29, 2001 | 04:18 PM
c5rose's Avatar
c5rose
Default Re: What's your tire pressure? (BruceF)
Thanks! Learn something new every day... Guess this is why I'm not an auto mechanic.
Old Aug 29, 2001 | 04:37 PM
Dave68's Avatar
Dave68
30 cold and 33-34 hot.
Old Aug 29, 2001 | 05:01 PM
ncvetteman's Avatar
ncvetteman
33psi all around
Old Aug 29, 2001 | 05:19 PM
Len16's Avatar
Len16
I like 28 psi cold - translates to about 30-31 hot.
Old Aug 29, 2001 | 06:08 PM
COOL Z06's Avatar
COOL Z06
I ran my RunCraps at 32psi (cold) and got 35,000+ miles on them (with some tread left over!).
I just put on a set of Michelin Pilot Sports and I'm still set at 32psi.
:cool:
Old Aug 29, 2001 | 07:18 PM
84Wolf's Avatar
84Wolf
I run 30 to 32 psi hot.
Old Aug 29, 2001 | 08:40 PM
DAP's Avatar
DAP
Default Re: What's your tire pressure? (84Wolf)
They should be 30 psi all around COLD (not driven). That reading on the tire wall is usually the maximum psi cold...
Note: moving your car raises the pressure quickly. I believe the sensors don't read correctly until 11-15 mph. So as soon as you pull away check before they get hot, and when you get to an air pump-guestimate how many pounds they need-and then drive around like an idiot :conehead trying to adjust them to within 1 psi of each other...
Note, the 18's out back tend to run 1 psi hotter than the ones up front-and every ten degrees of ambient temps raise/lower the psi by about 1 psi.
Even if the car is parked, and the sun is hitting one side and the other is shaded for a while-expect a slight difference in temps.
Old Aug 29, 2001 | 09:19 PM
Evil-Twin's Avatar
Evil-Twin
Default Re: What's your tire pressure? (DAP)
why would you want to check them before they get too hot??? they see that hot temp... for your whole driving experience.. the reason most ppl wear out their tires is that at 30 psi cold.. they get to 36/37 hot.. whicj raises the center and causes pre mature wear... HOT is were you want to get your rreading from.. cold is were the car is not moving.. the tires never wear out when they are cold.. cause the car isnt moving.. and ambient means nothing .. what does mean something is the road temperature.. black top can get to 160 degrees F. on a 95+ day with a lot of traffic.. same conditions on a cement road.. is 30 to 40 degrees colder .... check your tires when they are hot.. keep them at 30 psi...
Old Aug 29, 2001 | 09:34 PM
EuG's Avatar
EuG
Default Re: What's your tire pressure? (Evil-Twin)
Be very careful driving around on tires at 30psi hot. :nono: If you like going fast (100MPH+), it’s very dangerous because your tires are under-inflated and you’re risking a blowout at high speeds. :smash: You should keep your tires at ~30psi cold (which implies that it will be ~33-34psi hot) :yesnod: If you know you’re going for a very high speed run it’s even recommended to pump ‘em up to ~35psi cold (to lessen chance of a blow out). Of course you shouldn’t keep ‘em at 35psi cold all the time because of abnormal wear and bad traction/handling during non super-sonic :D speeds driving…
Just keep this in mind and be careful with tire pressures.
Old Aug 29, 2001 | 11:11 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: What's your tire pressure? (EuG)
runflats for the street 30 cold psi all the way around.
BFG G-Force R1's for the track 33 cold psi front, 35 cold psi rear. Adjust as track conditions warrant.
Old Aug 29, 2001 | 11:43 PM
DAP's Avatar
DAP
Dude, flat out...tires are to be checked cold, just like you don't check your car's oil right after you've driven it...
Inconsistencies abound in vehicles. The only thing that really is an acurrate measurment is when it is "cold." Certain racing tires perform better at certain psi's and heat ranges, but these are race tires...Goodyear's are to be kept at, and run at 30 psi, COLD (though some my find advantage ot over/under inflation for the track-depending). There performance, tread, wear rating is based upon when they warm up to 32-37 psi-based upon driving and environmental conditions.
To What's your tire pressure?
