Keyless Entry Always Needs to be Reset
Old Apr 25, 2022 | 02:48 PM
doninfosys99's Avatar
doninfosys99
4th Gear
Default Solved. New Key FOB not necessary
The battery had been recently replaced. The FOB would work while I tested it immediately after re-syncing it. Then stop. As it turns out, it stopped working several seconds after I released the lock/unlock buttons. Releasing the buttons relaxed the tension on the internal contacts within the FOB. I noticed that the case was not fully snapped closed. Upon snapping it fully, the FOB works perfectly.
