Coolant Change Procedure....Question
Old Jun 19, 2006 | 03:45 AM
LIGHTNING's Avatar
LIGHTNING
Default Coolant Change Procedure....Question
When i changed coolant in my '00 Coupe i followed shop manual instructions ...drained coolant...fill w/ water...run engine til thermostat opens....drain....repeat til almost clear. But i noticed in the '04 shop manual it says after u drain coolant...fill w/ water....let engine run 20 minutes! why is it necessary to run the engine for 20 minutes...especially since you'll be doing it 2...maybe 3 times til block drains clear?? change in engine design from '00 to '04??
Old Jun 19, 2006 | 11:01 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
One is a drian and fill, the other is a flush and fill. Sounds that way to me atleast.
