Took a very long ride on Saturday on the NE Crab run and gave the Speed Density Tune by ECS a good workout. I started out at 5am and returned home at Midnight so the car got to see all sorts of different air temps plus some cruising with A/C on since the temps hit the low 90s.
Again the car ran great. There were no surging issues or anything even with the different temperature changes (the day started out at 60 degrees at 5am and was into low 90s by 2:00pm). One thing I noticed and loved was the fact that I could run in 5th gear on the backroads doing 50 and then slowing down to lower the rpms to 1100 without having to change gears. In the past the car would buck below 1500, but now it runs fine. No need to change gears if I don't want to.
Throughout the day the car started right up and went right to the correct idle speed no searching.
when I first turned on the air the car idle did fluctuate at the first stop sign until it settled into the correct idle. After that it seemed to find the correct idle much quicker.
Overall I am still impressed with the tune. Next week I am going to Limerock so I get the chance to see how it does on the track. I assume it will be fine, but we will see.
Curious to see how it works out on the road course Bob. Waiting for your next update.
Road course should be a good challenge for the S/D tune and having Limerock in June and Watkins in July I will be able to see how it runs on a tight track and then on an open track.
Limerock, even though a small group was invited, will be tight so I dont think it will see too much fresh air. WGI is usually wide open so there is a much better chance for cleaner air.
Engine temps, outside temps, and lots of near redline running should be a good indicator of how the S/D tune holds up...
I understand some people run a SD tune only (read remove MAF) while others keep the MAF and couple it with an SD tune.
Several months ago I spoke to Rick at Synergy Motorsports (very personable, articulate, and knowledgeable guy BTW) and asked him several questions about SD tuning. SD tuning seems to be the way to go, ESPECIALLY if Forced Induction is part of the equation.
