Need Help With A/c Display Light
Old Jun 20, 2006 | 08:31 AM
bman1997C5's Avatar
bman1997C5
Default Need Help With A/c Display Light
I Am Not Sure If There Is A Fix For This Or Not. The Light On My A/c Display(1997 C5) Has Quit Working. Is This Something That Can Be Fixed Jsut By Changing A Bulb Or Do You Have To Purchase A New A/c Unit? Thanks In Advance For The Input.
Old Jun 20, 2006 | 08:59 AM
rws.1's Avatar
rws.1
It is most likely bad solder joints. Assuming that is the probelm, If you are good at soldering you can do it your self
If you are not it can be fixed for about $50
Here is a previous thread on the topic that has all the info you need whether it be self solder, outside repiar, or some info on bulb replacement if that is the issue.
good Luck
http://forums.corvetteforum.com/show...&highlight=dim
If this does not give your answers, do an advanced serach on HVAC ,dim display etc
