Error Code C1243 - Please help!
Old Jun 20, 2006 | 09:37 AM
jwilliams67's Avatar
jwilliams67
8th Gear
Default Error Code C1243 - Please help!
I purchased a 1999 Corvette about a year ago and shortly afterwards starting getting the Service ABS, TC and AH messages with a trouble code of C1243 BPMV Pump Motor Stalled. After checking a few things I purchased a used ABS from e-bay and had a shop install. No problems for 6 months. I'm now getting the service ABS, TC and AH with the same code - C1243 again. It pops up as soon as I start the car when the engine is cold and occasionally when I hit a bump in the road. I've checked the grounds in the engine compartment and everything is clean. Any ideas what else might be causing this? Thanks!
Old Jun 20, 2006 | 01:54 PM
FASST LN's Avatar
FASST LN
I had this same problem, though no one else seems to have it on this board.
What I did was to drive the car at about 30-35 mph and clear the DTC code which will make the ABS and TCS lights go off for just a moment. You then need to hit the brakes and engage the ABS system until the car almost stops. The lights will most likely come on again. Do this 4-5 times and the lights will stay off...for a while. They might come back in another month or two but you can just do this again. I suggest you do this when it is wet outside so you won't add a lot of wear to your tires.
Keep us posted if this works for you or not. You can also search for my post about the 1243 code.
Old Jun 20, 2006 | 04:27 PM
j99vette's Avatar
j99vette
i also have this problem with a few exceptions. randomly i will start the car and they will all come on but when i reset them they stay off. also they havent come on from hitting bumps but if i get on it and leave the t/c on the lights will come on. but again resetting will take care of it. im not sure whats wrong with it but i do know that the active handling feature does not work at all on my car. mine is a 99 mn6. the only fix ive heard is to replace the ebcm but that part was over $1000 and im not paying that.
Old Jun 20, 2006 | 04:48 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
http://www.stengel.net/diccodes.htm
give you a starting place
Old Jun 20, 2006 | 07:53 PM
Scoundrl's Avatar
Scoundrl
Good info here...
http://www.z06vette.com/forums/showthread.php?t=98527
Old Jun 21, 2006 | 09:57 AM
jwilliams67
8th Gear
Thanks for the replies!
To Error Code C1243 - Please help!
