How Much Oil
Old Jun 20, 2006 | 06:36 PM
PrimeC5's Avatar
PrimeC5
Default How Much Oil
How much shold be required for an oil change???? It's an 02 if that makes a diff.
Old Jun 20, 2006 | 06:39 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
6.5, but most use 7
Old Jun 20, 2006 | 06:45 PM
PrimeC5's Avatar
PrimeC5
Originally Posted by screw991le
6.5, but most use 7
Ok thank you very much I just got an oil change and they said 7 qt's but I had never heard of more then 5.5 so thanx for the info
Old Jun 20, 2006 | 07:52 PM
GrayC5's Avatar
GrayC5
Both the owner's manual and GM Service Manual say approximately 6.5 quarts with filter. However, much will depend on how well the system was drained when removing the old oil.
Old Jun 21, 2006 | 01:21 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Make it simple, dump in 7 quarts.
Old Jun 21, 2006 | 07:22 AM
EHS's Avatar
EHS
Old Jun 21, 2006 | 09:33 AM
BobbyG's Avatar
BobbyG
I use 7.0 quarts with a filter in my 04 Z06.
Bob
Old Jun 21, 2006 | 09:45 AM
PrimeC5's Avatar
PrimeC5
thanx guys for the replys I feel a lot better about it now
Old Jun 21, 2006 | 10:29 AM
dunbindun(tov)'s Avatar
dunbindun(tov)
I had always heard that it was better to underfill than overfill. Old wive's tale?
DBD
Old Jun 21, 2006 | 11:21 AM
Jackal's Avatar
Jackal
7 quarts for me.
Old Jun 21, 2006 | 11:23 AM
NSTG8R's Avatar
NSTG8R
DBD
it's not overfilling .. and the windage tray helps prevent the oil from splashing so dont worry bout it.
plus the manual also states if you're racing or "driving competitively" you should put 7 quarts in ..
Old Jun 22, 2006 | 01:37 PM
NavyVet's Avatar
NavyVet
Default Oil Volume
One more thing - make sure the rear end is higher than the front during the oil change or you won't get all the old oil out! Then, since it really is empty, use 7 quarts.
Old Jun 22, 2006 | 04:50 PM
TSDuke's Avatar
TSDuke
Exactly! Did mine last night, but my buddy has my jack so I had to drive up onto the rhino ramps. Needless to say, the front was higher than the rear, so I put 6.75 quarts of the new stuff (Amsoil 5w40) in.
To How Much Oil
