Intake question
Old Jun 20, 2006 | 09:06 PM
kylryn's Avatar
kylryn
Default Intake question
I have a 2000 stock C5 and I would like to know if it would be ok if I upgrade to a LS2 intake? Are they a direct bolt replacement? Will I get anymore HP out of this by going to a LS2 intake.
Thanks in advance. You guys are great with questions like this.
Old Jun 21, 2006 | 01:35 AM
N0TDADYS_98's Avatar
N0TDADYS_98
i'm not sure what year the LS6 intake became standard... but i'd go with an LS6 before i'd go with an LS2.
Old Jun 21, 2006 | 01:43 AM
GrayC5's Avatar
GrayC5
LS6 intake became standard on all C5s at the start of the 2001 model year.
2001 Press Release - More Performance
Old Jun 21, 2006 | 11:34 AM
rickkym's Avatar
rickkym
If you're only changing the intake manifold I doubt you's see/feel much of anything... Is that all you're going to do or is it a first step?
Someone else could chime in here, would there be any benefit? If you already have long tubes does the manifold only make any difference?
Old Jun 21, 2006 | 12:06 PM
Huckzilla's Avatar
Huckzilla
I'd go with the LS6 intake as well. However, you're not going to notice a difference with just that replacement. I would suggest the LS6 intake with an upgrade to your air induction (Halltech Stinger-R, Donaldson Blackwing, Vararam, Callaway Honker). A ported throttle body would also compliment those mods as it will improve throttle response. All of these, however, are still going to be restricted on the exhaust side. A nice set of long tube headers with hi-flow cats and aftermarket cat-back exhaust will really open up some power.
Good luck!
Huck
Old Jun 21, 2006 | 12:55 PM
MattB's Avatar
MattB
I replaced my intake with a LS6 and noticed a difference. I have a 2000 coupe with an A4. I've seen people here say that the LS6 is better than the LS2 intake, not sure why or if its true. but, I'm glad I put on the LS6 intake
Old Jun 21, 2006 | 02:26 PM
Face's Avatar
Face
The LS2 isn't a direct bolt on, you need a new fuel rail, throttle body, throttle body harness, and possibly other parts.
Old Jun 21, 2006 | 02:30 PM
voda1's Avatar
voda1
How about LS2 intake with LS2 ported throttle body?
Old Jun 21, 2006 | 03:23 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
The LS2 intake design seems to show little improvement over the LS6, even with the 90 mm tb.
Street Thunder magazine did some great intake testing on a cammed LS1. The LS2 W/90 mm TB only gained 6-7 fwhp over the LS6 W/ stock 75 mm tb in the high rpm range (over 5600). In the mid range it actually lost 5-6 hp to the LS6.
Check out the article. Hope this helps.
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
To Intake question
