Cats???
Old Jun 24, 2006 | 08:51 AM
NEVERL8C5's Avatar
NEVERL8C5
Default Cats???
I have the following codes p0300 and p0420 showing misfire and cat system low efficiency bank 1. would the cat cause the misfire if it is going bad or would the misfire cause damage to the cat . The engine has misfire on 1,3,5,7 cylinders and then all of a sudden will smooth out again but it returns to misfire within a short period of time. Pulled the plugs and they were not fouled as I would have suspected.o2's are reading so I am assuming they are ok. This is a stock set up and I would like to keep it as simple as possible any suggestions?
